2735 Views 13 Replies Latest reply: Apr 20, 2009 12:19 PM by silimtao RSS
silimtao Just Startin' 8 posts since
Jun 14, 2008
Mar 18, 2009 12:28 PM
How do I record using using the Toneport ux1?
I'm currently recording by using the Toneport's headphone out to my computer's mic/line in, using a 1/4" adapter for a 1/8"  cable. Everyone I've spoken to says I shouldn't have to do that, and having the usb cable connect should be sufficient. I'm using the latest drivers, and use XP Pro. I've tried changing the audio preferences to Toneport, ASIO drivers, auto-detect.
So, is the only way to input your guitar to record on a computer is by using the Port's headphone out to your computer's line-in? I get a lot of signal noise. On very rare occasions, everything is fine. But I would think I should be able to record via the usb connection only.
Thanks in advance.
  • LoonyBin-Fizzbin Gear Head 2,071 posts since
    Mar 26, 2007
    Mar 18, 2009 12:40 PM (in response to silimtao)
    Re: How do I record using using the Toneport ux1?
    Which DAW (Digital Audio Workstation)/recording software are you using?
  • ricksox UberGuru 11,600 posts since
    Mar 28, 2006
    Mar 20, 2009 2:23 PM (in response to silimtao)
    Connect your Toneport to your computer via USB and launch Gearbox 3.70. Set the Source Select in Gearbox to be "Instrument."
    In Audacity, go to Edit/Preferecnes/Audio and set your recording and playback device to be the TonePort.
    Press record in Audacity and you should be good to go.
    Line6Miller
    Please be sure to award Helpful and Correct points to  community members who respond with helpful or correct answers!
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Mar 20, 2009 5:36 PM (in response to silimtao)
    silimtao,
    First, please fill out a support profile so that we have a better understanding of your system:
    http://line6.com/account/supportProfile/
    Please disconnect any other USB device you may have connected to the computer (except for a mouse and keyboard) while troubleshooting this issue. Also, make sure to disconnect any USB hubs and try the UX1 on all of the USB ports on your computer.
    You may also want to try different headphones or speakers to connect the UX1's outputs. If you continue to have issues, you want to try on another computer to isolate the issue.
    Regards,
    Line6Hugo
    Mar 28, 2006
    Mar 23, 2009 11:41 AM (in response to silimtao)
    I know you originally did not want to do this but have you tried another recording application? Audacity is super limited so you may want to check your setup inside Ableton.
    Line6Miller
      • Misantropo Just Startin' 1 posts since
        Mar 22, 2007
        Apr 19, 2009 8:18 AM (in response to silimtao)
        Hi there
        Im really new at this kind of forums, im using the ux2 and have the same problem, i use cubase and volume is really low.
        I was used to this behaviour but i realiced that when i was recording after some hours the volume suddenly raised
        i have no idea whats going on but i think its the same problem as yours.
        I looked some information about this and the only entry i have found is yours, please if you have the final solution to this please write something about it.
        thank you
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Apr 20, 2009 10:02 AM (in response to silimtao)
    You very well might be a bad UX1 device after having gone through different host computer setups. This assumes that you had installed GearBox 3.70 and it's associated USB drivers for the UX1.
    You shouldn't be getting static/line noise that overbears the input signal. Usually, I've found that the modelled signal at the virtual output of GearBox is not as hot as you'd think, but if you have the amp channel output up high, the signal being sent into a host DAW should be healthy.
    Sorry, I've never used Audacity. I use Reaper and Live primarily and the only time I've seen a weak input signal from a TonePort USB device is when there is something problematic in the USB device, before the signal is passed to the USB port into the host computer.
    Our TonePort replacement warranty period is 90 days from the date of purchase on the retailer's receipt of sale. If you still have your receipt and are within that time frame, contact us at 818-575-3600 (8AM-5PM Pacific Standard Time, Monday through Fridays) and select the Service Department queue.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
