Oct 17, 2009 6:39 PM
Gear Tour: favourite Spider III setups for Live performances
Like (0)
This may be in the wrong area, but it is to do with Spider amps
What is your favourite setup, or what you consider the best setup for live gear using a spider III amp?
how to you set up your effects?
do you mic your amp or play it just all out loud??
Use this thread to share and discuss your favourite and best setups involving the spider III during live gigs
to kick things off, here is my favourite setup.
From guitar to amp:
Number of guitars
Wireless unit receiver
Wireless unit transmitter
Boss CS-3 Compression Sustainer
Dunlop Crybaby Zakk Wylde Wah
Boss AW-2 Auto Wah
Boss LS-2 Line selecter - BYPASS MODE LINE A LINE B
Line 6 Spider III HD150 head and 4x12 Cab Line 6 Pod X3 Live for effects Boss MT-2 Metal Zone Distortion
Line 6 Shortboard Marshall MG50DFX combo amp
Marshall footswitch
Mic used : house standard
Sometimes used straight depending on size of hall
line selecter allows mix of two amps together.
Any suggestions for improvements, or share your setup, leave a comment
think of it as your own little mini gear tour ![]()
when posting, the text messed up, after auto wah, it should say
bypass:
spider III head and 4x12 cab
shortboard
Line A:
X3 Pod live
Line B:
Boss MT-2
Marshall 50DFX
Marshall Footswitch
then onto mics
also, if anyone is having problems, that may be caused by the way things are set up, leave a comment and we can see if it can be fixed ![]()
