Line 6 - Support
1668 Views 2 Replies Latest reply: Mar 21, 2010 6:44 AM by Crimson RSS
olivaffair Just Startin' 4 posts since
Aug 12, 2009
Oct 19, 2009 4:38 PM
Midi recording too early
Hello
I'm using the KB37 with Cubase 5 and I seem to be experiencing the same problem as this person http://line6.com/community/message/50524#50524
After playing and recording the midi (reasonably) in time, upon playback the midi plays back the notes before they were truely recorded (please see screenshot for example of 2 bars of crotchets played on the beat).
I have tried the following the advice on the previous post but to no avail.
The system I am running is
MSIVR705 Laptop
Intel Premium Dual CPU 2.16Ghz
3 gig of Ram
Cubase 5.0.1
Any help would be much appreciated
Thanks
Leigh
  • line6antonio Line 6 Support 2,099 posts since
    Sep 26, 2006
    Oct 20, 2009 3:03 AM (in response to olivaffair)
    Re: Midi recording too early
    hi
    you'd better try your KB37 on a different PC, just to make sure your unit's ok
    if this is the case, this should be software or computer related (obvious... )
    the case mentioned on the other thread is different, it mentions audio and midi not being synchro, which may simply be caused by system's audio latency
    hope this helps
    cheers!
  • Crimson Just Startin' 3 posts since
    Aug 2, 2007
    Mar 21, 2010 6:44 AM (in response to olivaffair)
    Try rearranging your asio/midi connection, adjust the latency (play with it), make sure to disarm Audio recording tracks while recording midi...
    Pretty sure it would not do the same with another Daw
    Chuck
Bookmarked By (1)
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
