Oct 21, 2009 9:40 PM
Is there a comprehensive list of known problems/issues with Pod X3 Live?
Like (0)
I've found some things here and there, but not a thorough and complete list of known issues.
The release notes for the firmware releases have some things, but all listed separately with each release.
There are other issues and problems that are not directly addressed or fixed by firmware updates that should be grouped together too, or are actually misunderstandings of features.
Seems like it would be a super useful support resource for both users and Line 6 support staff.
I know that typically most manufacturers don't like to have big long list of flaws for their competitors to use as proof of an inferior product. I believe that this is flawed logic. If there are solutions to the problems then the help it would provide should outweigh the negative. And admission of faults is much better public relations than hiding the truth or obscuring the facts.
Otherwise there is bound to be unofficial lists posted elsewhere with no error/fact checking to validate the accuracy. Unofficial lists are even worse than official lists for a number of reasons.
Please provide a full comprehensive list of all known issues along with each respective solution/fix, explanation, or workaround.
Thanks
i think the idea of a known issues list, with all hardware faults that have happened, etc would bad for business... not that there's more faults that with other similar gear from other manufacturers, but it's asking for trouble, as no other ocmpanies like Line6 really publish that info. they keep it under wraps.
i also think with the firmware release notes, if it's an issue on a previous release, and not on the current release, that usually means it's fixed, or it'd still be a known issue...??
Hello,
We do not have a list for what you are asking for, but you can submit a feature request at the following link:
Feature requests
http://line6.com/company/contact/productFeedback/?topic_id=3
That is something you would probably have to do yourself, maybe create a group or something and create a document that is kept up to date based on the latest info from users. I think this could be really helpful to new users, instead of having to scour the forum looking for info on the problem they are having they could reference one document and find the latest status of any known issues including any possible work-a-rounds that might help.
