Line 6 - Support
4859 Views 16 Replies Latest reply: Dec 2, 2009 10:00 AM by Line6Andy RSS
Karl_Houseknecht Expert Line 6 User 3,374 posts since
Jan 25, 2007
Nov 1, 2009 6:27 AM
XDS+: RX2 light not lit - Problem found
http://line6.com/community/message/88604#88604
See original message for update.  Marking as question here because I can't reopen the original one.
  • Line6Miller Line 6 11,613 posts since
    Mar 28, 2006
    Nov 10, 2009 11:41 AM (in response to Karl_Houseknecht)
    RE: XDS+: RX2 light not lit - Problem found
    Karl,
      Where are we at with this at this point? Has Andy been working with you on this?
      Line6Miller
    Mar 28, 2006
    Nov 11, 2009 10:33 AM (in response to Karl_Houseknecht)
    OK great. Keep us in the loop.
      Line6Miller
      • dboomer Product Dev 1,422 posts since
        Oct 13, 2008
        Nov 13, 2009 1:01 PM (in response to Karl_Houseknecht)
        Re: RE: XDS+: RX2 light not lit - Problem found
        I never received an answer to my question as to whether you had tried different channel combinations?
        In any event I see three possibilities ... you have intermittent gear failure, line of sight issues or near/far issues.  I'm betting on the last one, but they are all difficult to determine.  If it works by itself with no other X2's on that tends to rule out gear failure.  Are your antennas near any metal .. maybe your pedalboard has a metal valence?  I think it's most likely that you've experienced near/far problems.  They happen if you get far enough away compared to another X2 unit getting too close.  If your bassist wanders over to your pedalboard and you wander away this can happen.
        When you switched transmitters did you also swap channels?
            Oct 13, 2008
            Nov 14, 2009 6:33 AM (in response to Karl_Houseknecht)
            Being on stage with UHF mics has absolutely nothing to do with it because they are on different bands.  Besides our digital system rejects all analog RF anyway.
            I thought we were talking about interference between you and the bass player.  Now I'm seeing a reference to a vocalist's wireless.  What is that?
            Was there a problem last night ... I'm not clear.
            I think you should contact service and send in the system so it can be checked.  That's the only way we will know if it has become intermittent.  Then we can go from there.
            818.575.3600 - service
                Oct 13, 2008
                Nov 14, 2009 7:22 PM (in response to Karl_Houseknecht)
                Karl ... there's no tone happening. You haven't seen it because I have been doing the writing ... but I have had the chief wireless engineer monitor these communications and I am trying to answer all his questions.  We just wanna get you up and running with the minimum hassle. Unfortunately "tone" doesn't really come across on short posts.
                The possibilities are always the same, gear failure, line of sight issues and near/far issues for any X2 problems.  If I had the units here I could troubleshoot them but across the internet it is very difficult to troubleshoot without very specific details.
                As I said, we need to get your unit here to check for gear failure so we can rule that out or fix it.
                I would like to get you up and running.  Please call service and we can rule out of fix the gear failure issue.
                    Oct 13, 2008
                    Nov 15, 2009 9:10 AM (in response to Karl_Houseknecht)
                    I think we need to see yours.  Isn't it the only one that has dropouts?
                    If they are all dropping out from time to time it is much less likely there is a problem in any of them.  I mean you "could" have to or three bad ones, but that is highly unlikely, but it is possible.  If it is just one receiver then it IS possible that you may have one of the two frequency receivers weak.  Normally you don't need both receivers.  But if you are having a combination of any of the three possible faults I laid out then that's where the second receiver kicks in.  If yours isn't up to snuff that "could" be the problem.
                    Intermittent problems are very difficult to solve ... especially when you don't have all the gear right in front of you.  That's why I've been pushing for very specific answers.
                    Call the service dept on Monday and get a ticket set up.
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Nov 13, 2009 4:51 PM (in response to Karl_Houseknecht)
    Karl,
        Did the singer's wireless change anything?  I remember there were a couple variables so I wanted to see if that situation changed anything.
    Jun 5, 2006
    Dec 2, 2009 10:00 AM (in response to Karl_Houseknecht)
    Karl - check your ticket now.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
