Line 6 - Support
3243 Views 5 Replies Latest reply: Nov 16, 2009 10:16 AM by Line6Andy RSS
mpolley Just Startin' 2 posts since
Oct 15, 2007
Nov 2, 2009 6:09 PM
Flextone III changes settings by itself
I have been having problems with my Flextone III XL. On several channel settings the amp will automatically change the settings on it's own. I have re-installed the latest flash memory to see if that would help......no luck. When the switch is made it is the same as if you press and hold the foot switch (shortboard) and it goes to some other setting. I think that it might be the default amp for the particular channel.
As a test, I connected thru midi and using Line6 Edit I was able to see that when it switches the gain button went from 25% to 98%. The auto switch still happens when the FBV is not connected.
I'm not sure what to do........any suggestions?  Is this a known problem?
  • spaceatl Expert Line 6 User 3,833 posts since
    Jan 24, 2007
    Nov 3, 2009 2:48 PM (in response to mpolley)
    Re: Flextone III changes settings by itself
    Holding a channel button on the FBV puts the Flex into "Manual Mode"...That means WYSIWYG....or wherever the knobs are set...You can think of it as a 37th patch but it is not very practical...My 5 year old Flex3 XL will do this sometimes...However, if the knobs are parked on zero is never happens...But that makes manual mode pretty useless...
    This sort of moving knob has occurred in every Line 6 combo I have owned...(AX2, Spider 2 120, Flextone III XL and SV112)...
    Park the knobs when you perform...
    The underlying problem...Well just a theory...There is a control voltage that runs through the pot...There are 128 steps of digital control on something like the gain, channel volume etc...Since the pot is analog, it can get into some halfway states where just a little vibration makes it send the position...A pot disable switch would be nice for performance...We have been asking for that one for years...
        Jan 24, 2007
        Nov 4, 2009 11:10 AM (in response to mpolley)
        You can always try hitting them with some contact cleaner...May or may not fix the problem...Voltage regulation is another approach on this...If you stablize the current with something like a Furman AR-15 then there is little chance that the voltage would vary during operation...Since the pot works on a constant voltage and acts as an AD converter of sorts, the more stable the power, the better...It also protects the crap out of your amp...
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Nov 12, 2009 10:17 AM (in response to mpolley)
    RE: Flextone III changes settings by itself
    Hello,
        This information is correct.
       Please be sure to award Helpful and/or Correct points to community members who respond with helpful or correct answers, and close out the ticket as “answered” if your situation has been resolved.
    Jun 5, 2006
    Nov 16, 2009 10:16 AM (in response to mpolley)
    Hello,
      It's been a couple of days since we've heard from you. We're going to assume your question has been answered and close this thread. If you still have questions please feel free to open a new question with us and we will answer your questions accordingly. Thanks!
Incoming Links
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
