8123 Views 18 Replies Latest reply: Jun 27, 2011 3:48 PM by silverhead RSS
Deneteus Just Startin' 11 posts since
Sep 6, 2007
Nov 4, 2009 2:07 AM
POD X3 Live - Full Black LCD / no sound.
My POD X3 Live was just sitting there after I got off work and it had been working for the past few days and all of a sudden there is nothing on the screen but a full black box.
Whats the deal with this?
I saw some threads about it but I would like to know what caused since there hasn't been any firmware updates applied to it recently.
I would send it in for repair but it was purchased from Musicians Friend online by a friend.
Whats the deal? Is it a bad firmware chip? A short?
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    Nov 4, 2009 5:59 AM (in response to Deneteus)
    Re: POD X3 Live - Full Black LCD / no sound.
    I believe some problems like this have been traced to apower supply failure. If you can, try another X3-compatible power supply.
    It also wouldn't hurt to reflash memory in safe mode. Hold down right nav key while powering up the X3 and use Monkey to 'Flash Memory'. The reinstall firmware. I know you've got the latest but sometimes a reinstallation of the software fixes things.
      • timowens Gear Head 1,230 posts since
        May 14, 2007
        Nov 5, 2009 6:16 AM (in response to Deneteus)
        If you got it from Musicians Friend and the firmware was already updated, I would say chances are they sold you a returned unit. If this is the case you should consider returning it no matter what and either get a replacement or a refund.
            May 14, 2007
            Nov 6, 2009 9:00 PM (in response to Deneteus)
            "Does this thing just need a new firmware chip?"
            Nope, I think it has given up the ghost all together! It is nothing you did, time for a replacement or refund.
  • ricksox UberGuru 11,600 posts since
    Mar 28, 2006
    Nov 12, 2009 9:43 AM (in response to Deneteus)
    RE: POD X3 Live - Full Black LCD / no sound.
    Hello,
      It could be a failed component like an LCD screen. Have you at least tried reinstalling the flash memory on the POD to see if that fixes it?
      If you have tried that to no avail then you should contact your local service center for repair. If the unit was purchased within the last year then it is covered under warranty but you'll need to get a copy of the receipt from your friend to provide to your service center.
      You can locate a service center near you at http://line6.com/support/serviceCenters/.
      Has this answer been helpful?
      Line6Miller
    Mar 28, 2006
    Nov 13, 2009 8:28 AM (in response to Deneteus)
    Hello,
      I'm not a repair tech so I can't comment as to why it would just stop working but it does sound like it needs to go in for repair.
      You should contact a local service center near you to arrange a repair or you can call us directly if you'd like to arrange the repair with us at our facility.
      (818)575-3600
      Let me know if this helps. Thanks.
      Line6Miller
  • Agarirg Just Startin' 3 posts since
    Apr 6, 2010
    Jun 6, 2011 1:20 PM (in response to Deneteus)
    If you are unable to fix it and find absolutely no use for your Pod X3 Live, I would be happy to buy it from you for a reasonable amount through ebay?  My e-mail is kenjiagari@gmail.com
  • vix01 Just Startin' 24 posts since
    Aug 3, 2009
    Jun 26, 2011 9:18 PM (in response to Deneteus)
    I you do the repair tha the above guy mentions and it still doesn´t works, you might have the sameprob as i do, and is easy to repair is a failure in the voltage regulators a tech geek did it for me and it cost me like 5 dolars and 1 hour of my time have technician to take a look at it you´ll save a lot of money and time
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
