Line 6 - Support
2262 Views 8 Replies Latest reply: Dec 25, 2009 2:37 PM by mikerbk2000 RSS
gregwoodbury Just Startin' 10 posts since
Sep 9, 2009
Nov 12, 2009 9:25 AM
FBV shortboard malfunction
     Yesterday I used my new Spider IV 150 w/ MK II shortboard with the band for the first time. I moved it from home, plugged it in and hooked up the shortboard. The amp worked and the board lit up but the volume pedal was on full and would not shut off in the heel down position. I was able to switch pre -sets but still no volume pedal. I procceded to use the gear without the pedal and after a while it started to work. Then the wah wah quit working. With the wah turned on both the green volume and the red wah light were lit, but the wah wah didn't function. After playing for a while I tried it again and it worked!  I've got it set up again at home and everything seem to be fine. What happened?  I bought this rig to try and simplify my gear set up but so far it's been a real headache. I confess that I'm not a techie and I may have bungled something but it was working fine at home ,and it's not as complicated as my Pod X3 Live pedal, which works fine...so far.
      Also the FBV calibration steps that come with the downloaded Advanced Guide for the Spider amp don't do anything. I followed the directions to "power off the board, press and hold the 'D' footswitch while powering on the board'. There's supposed to be an LCD readout :Calibrate Pedal" but there isn't any such display . So I don't know if this thing is even "Calibrated". It seems to work fine, when it's working. Is it actually necessary to calibrate it?
Thanx.....
  • Line6Hugo Line 6 6,317 posts since
    Apr 8, 2007
    Nov 16, 2009 4:06 PM (in response to gregwoodbury)
    RE: FBV shortboard malfunction
    Greg,
      Please check out the following knowledge base document for information on updating your FBV Shortboard MkII to be able to calibrate the pedal:
      http://line6.com/community/docs/DOC-1652
      Regards,
      Line6Hugo
    Apr 8, 2007
    Nov 18, 2009 8:58 AM (in response to gregwoodbury)
    Hello,
      It's been a few days since we've heard from you. We're going to assume your question has been answered and close this thread. If you still have questions please feel free to re-open this thread or create a new question with us and we will answer your questions accordingly. Thanks!
      Regards,
      Line6Hugo
      • mimungr Gear Head 649 posts since
        Mar 25, 2007
        Nov 19, 2009 6:25 AM (in response to gregwoodbury)
        Re: RE: FBV shortboard malfunction
        I don't understand why I have to plug the thing into my computer to "calibrate" it
        You don't have to connect it to your computer to calibrate it. You have to connect it to your computer to update the firmware. Support for calibration was added in version 1.1 of the firmware. If your shortboard has the older firmware (which yours almost certainly does), then you won't be able to calibrate it until you've first upgraded it.
        It works fine in the house but when set up in the garage with the door open the volume pedal still will not shut off.
        The pedal uses an optical sensor. If outside light is leaking into the sensor, then it's not surprising that the pedal would behave differently depending on the ambient light level.
        This thing is going back to Guitar Center tomorrow!
        That seems like the best plan to me, too.
  • mikerbk2000 Just Startin' 3 posts since
    Dec 25, 2009
    Dec 25, 2009 2:37 PM (in response to gregwoodbury)
    Re: FBV shortboard malfunction
    hi, i just got the Line 6 FBV Shortboard mkii for christmas and i can't figure out how to switch the pedal from volume to wah. i heard theres a toe switch but when i press the pedal all the way down there is no switch. is it broken?
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
