Line 6 - Support
7259 Views 36 Replies Latest reply: Dec 28, 2009 11:38 AM by veets987 RSS
fester2000 Iknowathingortwo 1,050 posts since
Oct 30, 2006
Nov 12, 2009 11:13 AM
Soundclips w/ M13, Michael Kelly and Egnater Renegade 65
Finally got around to recording a few things with the new rig.  There will be more to come.
This a Michael Kelly Patriot Custom (neck pickup, coil tapped) into the Egnater Renegade 65 watt head (clean channel) using the 4CM with a L6 M13.  The head feeds a 1936 Marshall 2x12 with T-75s.  Mic'd with an SM58 into a Toneport UX-2 into Reaper.  The only post-processing I did was to mess with the levels a bit and added a limiter to squish a couple of high peaks and to slightly boost the volume overall.
The first round of playing is bone dry, no fx or anything.  The 2nd set of clips uses the M13 in the loop for a rotary w/ horn and a delay (the digital w/ mod, I believe) and I used the amp's reverb.
The amp is really amazing, by the way.  It has two fully independent channels, each of which have the following variables: 18/65 watt switch; a "tight/deep" switch; a "bright/normal" switch; preamp gain; eq (bass, mid, treble); "tube mix" (lets you blend any combination of the amp's 6L6 power amp with the EL34 power amp -- really cool!), master volume and reverb.  There is also a shared presence, density, and "main 1" and "main 2" master volume controls.  These all work with the included footswitch, which lets you switch channels, turn the fx loop on or off, turn the reverb on or off, and engage the 2nd master volume control.  Each of these elements in the footswitch can be assigned to either channel or both.  So if you wanted to use reverb on the clean channel but not the od channel, you can assign the footswitch to let you turn the reverb on and off for channel one but not channel two.
So I recorded some other stuff with my strat and hope to be able to post that stuff this evening.  Let me know what you think and if you've got stuff you want to hear, let me know.
Cheers,
Fester2k
  • Karl_Houseknecht Expert Line 6 User 3,374 posts since
    Jan 25, 2007
    Nice and sparkly clean!  Try that song intro with the tri chorus and some delay.  385ms with about three repeats audible.
    Now...bring on the DIRT.
      • cgtrox Expert Line 6 User 1,440 posts since
        Jan 25, 2007
        Dude! That amp sounds VERY nice! That M13 really sounds good, too. I know what you mean vs. the POD effects, night and day...
        cgtrox
        Jan 25, 2007
        Nice analog delay on that last lead passage.  I like the sound you have going on there, but you know I wanted to hear the MK.
      • sofnwhat Just Startin' 684 posts since
        Jan 25, 2007
        Dang dude, that amp sounds sweet!
          • wardick Just Startin' 375 posts since
            Dec 31, 2008
            Both clips sounded good.
                • aaron__aardvark Just Startin' 1,202 posts since
                  Jan 25, 2007
                  fester2k,
                  I think all 3 clips have nice tone!
                • dasvox Just Startin' 381 posts since
                  Jan 29, 2007
                  Double A is right. Nice! Good fingers and gear. All you guys have me gassing for the M13 now.
                    • Mcgill Just Startin' 338 posts since
                      Jan 25, 2007
                      the M13 is a beast of a pedal.  Unless you've just got to have old school analog equipment (and I can respect that, I really can), this thing to me is the shining star in L6's lineup right now.
                      Cheers,
                      Fester2k
                      I will never hear any of this gear unless I import it! So!!!
                      I have some questions!  The M-13 VS the M-9  Are the things you are doing doo-able? Or is it like comparing apples & oranges?
                  Jan 25, 2007
                  Man, that's FAT.  I hear some good tone in there.  Just a little too congested in the midrange, though.  Great tone from that rig you've got there!
  • mattphelan1 Just Startin' 3 posts since
    Feb 19, 2009
    I had the exact same rig a few months ago. Sold it before I could get it all working nice. Wish I didn't!
      • Matt_J71 Just Startin' 103 posts since
        Jan 25, 2007
        Fester, are you using the 4 cable method with the M13 and head, or just using the M13 for effects?
        This guy on youtube has some nice clips with the Egnater - I love his lead tone, and he is just adding a Boss delay in the loop.
        http://www.youtube.com/watch?v=QTlrA8dwDRE
        He has a couple of other clips with the Egnater that are good too.
            Jan 25, 2007
            Did you get my PM?
            And when can I expect shipment of this amp?
            Please I am not being serious at all!
            But Maybe one day?  (Alas its not on my list) But should be!  For now I just place realistic objectives on "The List" !
      • veets987 Just Startin' 8 posts since
        Dec 16, 2009
        I have the same head.  Love it.  Its simple and extremely versatile.  So what tubes exactly did you swap out and what did you end up replacing them with???
