3144 Views 7 Replies Latest reply: Sep 15, 2010 8:33 PM by machinefish RSS
bogasnacks Just Startin' 4 posts since
Nov 17, 2009
Nov 17, 2009 8:29 PM
Increased Verbzilla noise with trails switch enabled?
Hi guys,
Just got my brand new VERBZILLA today and want to use the trails feature, but when I switch it on, there is noticable static/hum while the effect is OFF. I just want to know if this normal? I'm guessing with the trails feature enabled, the FET bypass is disabled?
My set up is:
Les Paul Standard w/ Burstbucker Pros
Boss TU-2
Ibanez TS9
VERBZILLA
into the front of:
JCM 800 2203
I tested it like this:
1) Effect is off, trails is OFF. some amp hum is audible from speaker
2) Effect is off, trails is turned ON, increased hum from speaker is audible
All pedals are powered by PEDAL POWER 2. Anyone else have this problem? Please note that I don't have an effects loop on my amp.
Thanks for your help!
Brian
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Hello,
        it sounds like a couple things may be happening here:
      1) be sure that all the pedals in your audio chain are powered by the same power strip, and change all your cabling.  Try moving the pedals and power cables around to see if this changes your noise situation.
      2) Check the following document for ore trouble shooting:
      Troubleshooting Line 6 Modeling (four-button stomp) and Tonecore pedals
      http://line6.com/community/docs/DOC-4490
      ToneCore Pedals FAQ
      http://line6.com/community/docs/DOC-4166
      3) Try a different Verbzilla to see if the behavior can be duplicated.
      Please let us know if you need further assistance, or close out the ticket as “answered” if your situation has been resolved.
    Jun 5, 2006
    Hello,
      It's been a couple of days since we've heard from you. We're going to assume your question has been answered and close this thread. If you still have questions please feel free to open a new question with us and we will answer your questions accordingly. Thanks!
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
