Line 6 - Support
2360 Views 4 Replies Latest reply: Nov 23, 2009 11:28 AM by Line6Perry RSS
Fullofarts Just Startin' 6 posts since
Apr 18, 2008
Nov 19, 2009 10:44 AM
UX2 Tone Port with Pod Farm and Logic 9.01
I have a couple issues with the UX2 on my Imac.
Monkey tells me that i have all the current drivers etc.
1) Although it works for the most part,
When opening Pod Farm as a stand alone, I always have to choose the UX2 if I start Pod Farm where it used to be able to find it.
2) If possible, How can i get the UX2 to record two inputs at the same time, on seperate tracks in logic 9 ?
for example: Mic 1 and Inst 1      (Gear box seemed to offer this, although I never tried it)
3) Is it possible yet to choose the UX2 inputs within the logic as the host app?
Thanks, Todd
  • Line6Miller Line 6 11,613 posts since
    Mar 28, 2006
    Nov 20, 2009 2:53 PM (in response to Fullofarts)
    RE: UX2 Tone Port with Pod Farm and Logic 9.01
    Hello,
      1. In POD Farm go to File>Preferences and select your device for the "Launch POD Farm Using" drop down menu and then click on Apply.
      2. In POD Farm make sure to create a Dual Tone and then set the source select for each tone.
      3. I am not entirely sure I understand your 3rd question. Can you elaborate? Thanks.
      Line6Miller
  • Line6Perry Line 6 Support 6,641 posts since
    Dec 26, 2007
    Nov 23, 2009 11:28 AM (in response to Fullofarts)
      The answer to #3 is a Logic setup answer, which unfortunately we don't have. Your account indicates that you have a POD Farm Plug-In license installed in the UX2, which allows you to run the AU Plug-In effect within Logic.
      The limitations of the UX2 is such that you can only really ever have 2 simultaneous inputs, but POD Farm needs to be open to select the input source(s) and the Mixer page in POD Farm Standalone shows you the routing option.
      There still maybe a setup or two in the software settings of Logic you'll need to know how to do to make it happen. For what's it's worth, here's a screenshot doc on how to route two different input sources with a UX2 into GarageBand: http://line6.com/community/docs/DOC-4401
      Regards,
      L6Perry
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
