Line 6 - Support
1142 Views 30 Replies Latest reply: Jul 6, 2010 2:38 PM by rhhicks RSS
rhhicks Just Startin' 16 posts since
May 26, 2008
Nov 21, 2009 8:18 AM
Why Does My POD XT Live Go Mental?
I'm borrowing from a semi-off-topic post from a Bass Pod poster's thread here: http://line6.com/community/message/95307#95307. I have a guitar Pod XT Live with psycho gain management symptoms.  While playing, the unit will spontaneously leap huge increments in volume, either upwards or downwards.  I'll readjust my amp gain to compensate and then eventually, wham... off it goes to a radically different new volume setting.  I'm not 100% on this, but I think I'm seeing this phenomenon more often when the unit is cold then after it has been powered on for some time.
Took it to an authorized repair shop in Wheaton, MD and after $100 and several round trips, it now seems to be a little worse.
No active electronics, just a passive Tom Anderson hollow drop-top directly into the unit.  Cables are fine.
One thing I've noticed just by diddling with the thing, sometimes, immediately after one of these spontaneous gain changes, if I either (1) whack the volume pedal with my foot or (2) wiggle and reposition the "Drive" knob, the unit gain will restore to what it was just prior to the madness, but sometimes not.  Last night I updated all of the unit software, reflashed the unit and calibrated the volume pedal.  If I knew of any other possible remedies, I'd try them as well.
Is anyone aware of a calibration or reset procedure for all of the rotary encoders on the unit?
Because the unit is so flaky now (despite being well taken care of - no drops, etc.), I can't trust it in a live performance situation.  The changes in gain are so prominent that it's disruptive to any performance.  Also, like one of the other posters earlier in this thread, it's also becoming too much of a pain in the butt to practice or rehearse with.  It's a shame because I am really fond of some of my home brew user patches, but I'm now afraid to use the thing.
Any deep knowledge Pod XT Live medicine men out there?
  • Mcgill Just Startin' 338 posts since
    Jan 25, 2007
    Nov 21, 2009 9:07 AM (in response to rhhicks)
    Re: Why Does My POD XT Live Go Mental?
    Try this:
    No guarantees though!
    With your Pod Powered Down (off) rotate all your knobs about 20 times each.  Just to clear posible dust around the poles! Then place all your Knobs at the "Zero" mark!
    Now Power up your Pod!  Without touching the Knobs, and only using your Footswitches and Wah/volume pedal, try to make your pod behave the way that you discribed?
      • greghfd Just Startin' 7 posts since
        Oct 4, 2007
        Nov 23, 2009 1:33 AM (in response to rhhicks)
        Good one rricks, now we have a name "Psyco Gain Management Syndrome".
        I'm wondering if other pod xt's with PgMS are close in date or serial number.
        Mine was new in December 2005.
        They may all have the same faulty component.
        Last week it came back from the line 6 doctor who reported that it was tested for 2
        hours with no fault aparent. Before I sent it ( 200 Km +) for repair I explained
        that it can take 3 or more hours to play up if it feels like it, so you can guess how
        happy that made me.
        Anyway, I won't winge any more (for now) but I'd like to know how old yours is & if
        their close check serial numbers. What do you think ?
  • Line6Miller Line 6 11,613 posts since
    Mar 28, 2006
    Nov 23, 2009 10:09 AM (in response to rhhicks)
    RE: Why Does My POD XT Live Go Mental?
    Hello,
      What you are describing sounds like a failing potentiometer. It's most likely the channel volume pot that is failing. I'd suggest taking the unit back to the service center and letting them know that they did not fix your issue. Tell them you think you have a pot that is failing. They can test it and verify.
      http://line6.com/support/serviceCenters/
      If you'd like, you can also arrange a repair directly with us.
      (818)575-3600
      Please let me know if this answer has been helpful. Thanks.
      Line6Miller
    Mar 28, 2006
    Nov 24, 2009 8:53 AM (in response to rhhicks)
    If you'd like to contact us about a repair that is perfectly fine. We'll do whatever we can to help.
      If all of your questions have been answered please be sure to award Helpful and/or Correct points to community members who respond with helpful or correct answers, and close out the ticket as “answered” if your situation has been resolved. Thanks!
      Line6Miller
      Oct 4, 2007
      Nov 25, 2009 3:09 AM (in response to rhhicks)
      Ok. I've just unpacked & set up my xt again, it took 24 mins to loose it (so much for being tested for 2 hours) but what is happening now and perhaps
      ( he says sheepishly) may have been happening all along is that I can still control its volume via the channel volume pot, so what happens when PgMS strikes is that it ignors the input from the pedal and just goes to the channel pot setting regardless of what you do with the pedal & stays like that until you restart. Yes, I do fell dumb for not realizing this before but, as I said, I set up on PC & dont normally move the nobs from 12 o'clock. So the problem with mine is that the pedal stops talking to the rest of the machine. I'll talk to the techs here again tommorrow and see if this rings a bell.
      Does this still sound the same as yours?
          Oct 4, 2007
          Nov 27, 2009 4:39 AM (in response to rhhicks)
          G'day rhhicks, just a quick note this time, after a pgms attack "all" the pots on mine still work it's just that the pedal has no effect on anything,
          it's as if the pedal has become dissconected from the unit. So if I'm playing with the pedal controling volume at 30% and pgms hits the volume goes to 100% with no pedal control but I can still turn it down via the channel pot.
          I got onto my nearest line6 repairer & explained this to them yesterday and was given 2 options, as it's out of warranty I could either (A) send it back to them again & have a new board fitted at aprox $400.00au or (B) upgrade to the new model which they are being told is more reliable. This I thought was an odd thing to tell a customer but there you go.
          I'm actually considering my own option (C) involving the xt being a weighty little bugger & my enjoyment of fishing.
          I have a tech mate who specializes in sound gear, I did'nt want to involve him thinking line6 would sort it out for me but I've lost hope of that.
          I have a buisness myself and certainly don't expect anything for nothing but $400.00 to repair mine when they retail a new one for $599.00 seems a
          bit harsh.
          So I'm a bit dissapointed but happy to be playing with my collection of stomps again, and you know, some are over 25 years old and still sound brand new !
          As always let me know if you get any info, cheers.
    Mar 28, 2006
    Nov 30, 2009 10:22 AM (in response to rhhicks)
    Did you receive an RMA from us or did you opt not to? Are there any service centers in your area that could look at the POD?
      Line6Miller
      Oct 4, 2007
      Nov 30, 2009 6:10 PM (in response to Line6Miller)
      Re: RE: Why Does My POD XT Live Go Mental?
      G'Day Miller,
           I did'nt get an RMA from you as I assumed your offer was intended for rhhicks.
      My nearest service centre is in Melbourne Australia (as far as I know).
      As you can see from my post on 27-11-09 I have already had it in for repair & it was
      returned to me with no fault found, in reality it's as bad & unusable as ever.
      Concidering what I've been quoted in parts to repair, it's just not worth it.
      Would an RMA make any differance to the repair cost or do I just write it off.
      Thank's anyway for the response.
                                              greghfd.
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Dec 2, 2009 9:59 AM (in response to rhhicks)
    It sounds like the there are a couple things that could be happening here.  Here is what we recommend:
      1) Calibrate the expression pedal with the following link:
      PODxt Live: Troubleshooting and Calibration
      http://line6.com/community/docs/DOC-4747
      2) Park your tone/gain knobs at 100%.  This will help guard against changes in the patch due to vibration.
      3) One thing to look for - if/when you notice a channel volume drop, look at the LCD to see if the knob has changed position.  If the knob is parked and the position changes it sounds like a bad pot, which can be replaced at your local service center.
       Please be sure to award Helpful and/or Correct points to community members who respond with helpful or correct answers, and close out the ticket as “answered” if your situation has been resolved.
    Jun 5, 2006
    Dec 8, 2009 4:14 PM (in response to rhhicks)
    Hello,
      It's been a couple of days since we've heard from you. We're going to assume your question has been answered and close this thread. If you still have questions please feel free to open a new question with us and we will answer your questions accordingly. Thanks!
        Oct 4, 2007
        Dec 9, 2009 5:36 AM (in response to rhhicks)
        G'day Rhhicks,
                  Well after trying all sugested fixes, I've found the best option is to lick my wounds and NEVER buy another pod.
        Support is'nt there, except to "buy a new one cause we've been told their more reliable".
        Once the warrenty ends, so does the interest.
        Good luck with your playing & buy quality stomp boxes instead.
    Jun 5, 2006
    Dec 11, 2009 4:39 PM (in response to rhhicks)
    If you are not experiencing the situation on a regular basis, you will need to keep an eye on the situation and try the suggested solutions if/when the situation occurs.
  • ballnmike Just Startin' 8 posts since
    Oct 20, 2009
    May 5, 2010 2:46 PM (in response to rhhicks)
    My POD Xt Live Pedal is broken too. You can easily replace the PCB board that is in the machine under the pedal. I have the same issue with massive fluctuation in volume and wah. It goes back and forth from 40% to 100% like 10 times a second. You can easily replace the "Pedal PCB" (microchip) under the Pedal. I opened my case up and tested all the surface mount solder joints, resisitors, and capaictors. Everything looked and tested good. If something looks burnt, thats probably your problem. I plugged the unit back in and noticed that, When the machine was on, There was a very dim red glow to one of the optics. Now if these optics work like a optical mouse, that light should be way brighter, pretty close to as bright as your mouse. My theory is that it is the transmitter optic that is going out on these boards. I talked to Line 6 parts department and told him that this seems to be a common problem with what I read on the forums. He said they havent been giving out very many of these boards. So I suggested that most people are probably giving up, or doing some kind of work around and just not reporting on the forums, or they are just not doing it themselves. I think Line 6 needs to address this issue because it looks like it is happening to a lot of these Pod's. Well none the less they are sending me a new "Pedal PCB" board. When I get it I will post the step by step replacement procedure and pics as well. It looks like you can buy this from thier authorized repair centers and do it yourself. The 3 that I have locally all gave me the run around so I called Line 6 and told them my story. Only after I said that my last resort would be to ...buy another new Pod and replace the part and return the new one... Did they offer to send me the part for free. Apparently they are not allowed to sell you the part but they can send it to you. They dont just offer up the part, you have to kinda hassle it out of them. Dont be like me and waste countless hours trying to find line 6 parts suppliers online, You just wont find them!!
      Oct 20, 2009
      May 24, 2010 11:06 AM (in response to ballnmike)
      Problem Solved.
      As I said earlier you need to replace your "Pedal PCB" I got the new part and now my POD XT Live works just fine!! This part is $150 from the repair center. Its a simple replacement. If you can play a guitar alright you should be smart enough to replace this part yourself. I hope line 6 sees that this is a common problem and reduces the price a little bit for the rest of you!!
        • d8veh Just Startin' 102 posts since
          Sep 26, 2007
          Jul 6, 2010 2:31 PM (in response to rhhicks)
          Just in case you havn't already checked it, and to help anybody else reading. When you transport the XT Live in the gig bag or anything similar, it's easy to knock the norm/pad switch into the half-way position. This can give the symptoms you describe, i.e. indecriminate changes to patch volumes.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
