Nov 21, 2009 12:43 PM
spider2 212 with no sound
Like (0)
Just picked up a used spider 2 212, when buying tried it and sounded great functioned perfectly, got it home, and it powers up, lights flash etc... but no sound. Ive tried the a channel reset thing, no help. trying the power on while holding the tap button gives it sound, but just one sound no adjustments, all the knobs all make the channel select lights move after doing this. ive exhausted the net huntin for the correct procedure but i guess im missin it, any help would be appreciated....btw the way ive tried it in several power outlets as well with no help.
Holding the tap button with the power on bypasses the DSP preamp. The signal still goes through it to get to the power amp section so the DSP is working (sorta). That is good news. Also the power amp seems to be working which is wonderful news.
Since the lights all work and the DSP is working in bypass mode and the model selector seems to work (lights change as you turn it) the problem may be the channel volume knob. (my best guess).
Try starting the amp normally then playing with the channel volume knob. If you have your master volume up enough, guitar plugged in and turned up enough, you might be able to get the channel volume to make contact and make some sound, if that what's wrong in the first place.
If the channel volume is warn out its contact will be changing. If the return from that pot changes the DSP will automatically go with that setting, in this case might be "0" (my though). Try turning the channel volume and see if you can luckly get some sound. If you do then that pot is bad. If its bad then the entire daughter board its on must be replaced by L6. lol
Eventually you are going to need to take the amp to an authorized L6 service center for repairs. They are the only place that can get the necessary parts and they must also install them, so if you want that amp fixed right you are basically going to haft to take it to one.
Good luck
M^T
Hello,
If the reset of the amp did not change the behavior then you should contact your local service center and arrange a repair.
http://line6.com/support/serviceCenters/
Please let me know if this has answered your question. Thanks.
Line6Miller
Hello,
It's been a couple of days since we've heard from you. We're going to assume your question has been answered and close this thread. If you still have questions please feel free to open a new question with us and we will answer your questions accordingly. Thanks!
Line6Miller
