Like (0)
Currently Being ModeratedNov 30, 2009 4:04 PM (in response to nolanpj)Re: When will Workbench be compatible with JRE above 1.5? Sun no longer allows downloads of 1.5.
You can keep older versions of Java on your computer. i have both and the programs that need 6 use 6 and Workbench etc. use v 1.5.
btw there is no way to purchase Workbench software, so i think you're confused on that point.
- Report Abuse
Like (0)
Currently Being ModeratedNov 30, 2009 6:34 PM (in response to Mr_Arkadin)Re: When will Workbench be compatible with JRE above 1.5? Sun no longer allows downloads of 1.5.
i think if you don't have a pod/vetta with the VDI you would be paying for workbench with the variax interface... just FYI
- Report Abuse
Like (0)
Currently Being ModeratedDec 2, 2009 11:18 AM (in response to Mr_Arkadin)Re: When will Workbench be compatible with JRE above 1.5? Sun no longer allows downloads of 1.5.
That's right. If you only have a variax, you must purchase workbench. Got mine off of ebay. I do think you're right about the java though. As long as you don't remove the 1.5 version, it should still work.
- Report Abuse
Like (0)
Currently Being ModeratedDec 4, 2009 3:57 AM (in response to gitarzan53)Re: When will Workbench be compatible with JRE above 1.5? Sun no longer allows downloads of 1.5.
Workbench is a free download software. It can be used in conjunction with the Vetta or PODs (only models provided with the "Variax Plug"). For those without the foregoing, a separate interface can be purchased which comes packaged with a Variax cable (3M) - the software still has to be downloaded, or at any rate updated via Monkey.
- Report Abuse
Like (0)
Currently Being ModeratedDec 4, 2009 10:54 AM (in response to Mr_Arkadin)Re: When will Workbench be compatible with JRE above 1.5? Sun no longer allows downloads of 1.5.
Thank you for the response. I couldn't find anywhere on Sun's site if you can run two different Java versions at the same time. I have the workbench on my DAW and didn't want to affect other applications because this is my baby. You running both confirmed to me that it was OK to run both. I downloaded the older verion from the developer archive site. Installed it and al is working great. Thanks again.
- Report Abuse
Like (0)
Currently Being ModeratedDec 2, 2009 1:51 PM (in response to nolanpj)Re: When will Workbench be compatible with JRE above 1.5? Sun no longer allows downloads of 1.5.
You can get an older version of Java from here...
http://java.sun.com/products/archive/
Select version 5.0 for download, then choose the JRE version. Download a copy, install, and presto, Workbench works. And you get to keep the newer version 6.1 as well. There's no need to downgrade so to speak...
- Report Abuse
Like (0)
Currently Being ModeratedDec 4, 2009 4:03 AM (in response to nolanpj)Re: When will Workbench be compatible with JRE above 1.5? Sun no longer allows downloads of 1.5.
There is also a small utility available called JBuster which will allow it to work with a newer version of Java,
- Report Abuse
Like (0)
Currently Being ModeratedApr 24, 2010 10:25 PM (in response to nolanpj)Re: When will Workbench be compatible with JRE above 1.5? Sun no longer allows downloads of 1.5.
Can someone help me with this Java issue for a Vetta II combo? I just installed a new hard drive on my CPU and cannot get L-6 Edit to work. Used to worl fine w/ older hard drive. Monkey uploaded and works fine. I tried someones suggestion of downloading an earlier version of JRE 5.0 but could only find 6.0 on the Sun site, also R&R'd L-6 Edit 4 times, rebooted CPU, watched a movie, had a couple of beers, hafl pint of ice cream, and now I'm outta gas. My OS is XP pro... I have run out of ideas. Perhaps the program S/W needs new patch. I went to the Sun website but could only find JRE 6.0.
If sombody has an earlier copy of Java 5.0 please post it here!!
Too late... tired and off to bed. check in tomorrow...
Appreciate HELP from anybody !!!!!!!!!!!!!!!!!!!!
Frustrated,
Griff
- Report Abuse
Like (0)
Currently Being ModeratedApr 25, 2010 1:52 AM (in response to griff46)Re: When will Workbench be compatible with JRE above 1.5? Sun no longer allows downloads of 1.5.
A link to download Java 1.5 (which is what you need to run workbench)
http://www.oldapps.com/java.php?old_java=3
It certainly worked for me on my XP machine........
There are links to all of the other releases of Java there as well.
Good luck
- Report Abuse
Like (0)
Actions
- Retrieving data ...
Legend
- Correct Answers - 5 points
- Helpful Answers - 3 points
About
Follow
Subscribe
