2808 Views 4 Replies Latest reply: Mar 27, 2013 4:51 AM by asg-pro RSS
the_philth Just Startin' 6 posts since
Mar 21, 2007
Dec 23, 2009 12:25 PM
HELP: Flextone III XL Only Left Ch. Working
I'm sure this can apply to most Line 6 stereo amps, but I'll only refer to my Flextone here, as I'm sure someone with a stereo amp may have had or will have this problem in the future --- ergo, this thread will not only help ME and MY situation, but will hopefully help others!
Okay so, I loaned my combo to a friend (so he doesn't play guitar through the P.A. --- which he always does) so he can play a gig in Vegas. When I get it back a few weeks later, I'm hearing sound from the Left speaker only. The only change that was made --- I performed a Factory Reset and auditioned each setting with the Floorboard before I dropped it off at my friends studio.
I'm hoping that it's something like a Power IC or a Fuse that I can swap out myself. A bit of heads-up; I have a feeling the Perp' shoved his Boss ME-70 in front of the amp as he usually does with the house P.A. Maybe that helps with troubleshooting(?). There's also no buzzing/hissing or humming coming out of the Right speaker whatsoever; it's completely silent.
Thanks in advance to you guys for your suggestions!
~phil
    Mar 26, 2007
    Dec 28, 2009 6:33 AM (in response to the_philth)
    Re: HELP: Flextone III XL Only Left Ch. Working
    I hate to say this, but don't lend gear that you value to anyone   I've been caught myself more than once by someone else mis-using kit I've loaned them in full working order and breaking it, scratching guitars etc..., and I've seen other people suffer the same fate.  It has to be said that it's more acquaintances with whom I've been friendly that have acted this way rather than long term friends.  There are a lot of freeloaders around unfortunately.  they rarely accept any liability, their wallets tend to stay firmly shut and it's 100% impossible to prove sometimes even when you're in the room when the problem occurs.   It's a hard lesson to learn, even though I'll do my best to help anyone out, however nowadays, no-one but me gets to use my good amps and my good guitars (even though it goes against the grain to appear to be so tight-a*sed about such stuff) and I would not expect anyone to loan me their gear either as I'd hate for anything to happen to it whilst in my possession.
    Anyhow as to the cause of your amp's problem.  It sounds as if either the speaker on the non functioning side is damaged - and you can easily check this by swapping the spade connectors from the speaker that is working onto the apparently non-working one (ensure you remember which wires are attached to which terminals and tape up any temporarily disconnected wires so they don't short on each other or anything else), or the power amp on that side has a problem.  The second scenario is more likely IMO.  I'm not familiar with the Flextone III XL but if it has an extension speaker socket on each output, I wonder if your friend has attached an extension speaker cabinet to the affected side's output or perhaps the PA guy has attached a DI box of some sort to that output, caused the speaker load impedance load to drop below 8 ohms (assuming the Flextone III XL is set for an 8 ohm output like the Spider amps are) and popped a power transistor protection fuse (if there is one - there should be but I wouldn't guarantee it) or the power amp module itself.
    Shoving an FX board between the guitar and amp input should not have caused any problems.
    You really need to get the amp checked out and repaired by a qualified technician at a Line 6 authorised repair facility it would seem, and then depending on how you feel about it and how much you value your friendship, try to get your friend to cough up something towards the cost of repair or rental costs for the privilege of having borrowed your gear to do a paid gig (I assume he did get paid) - good luck on that one.
    I hope it is something simple (and inexpensive).  Good luck.
    Nick
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Jan 8, 2010 10:04 AM (in response to the_philth)
    RE: HELP: Flextone III XL Only Left Ch. Working
    This information is correct.  Please take your unit to your nearest repair center for diagnosis/repair:
      GPS Electronics
      13045 Tom White Way Suite I
      Norwalk, California 90650
      562-802-0840 (phone)
       Please be sure to award Helpful and/or Correct points to community members who respond with helpful or correct answers!
    • asg-pro Just Startin' 3 posts since
      Mar 19, 2013
      Mar 27, 2013 4:51 AM (in response to the_philth)
      Hi phil,
      it's almost two years since your post but maybe you can help...
      I'm working on replacing the ICs of my Flextone HD 2 power amp boards. It's the ICs that are attached to the heat sink, right? Mine only have 3 legs but the Digi-Key part you mentioned seems to have 11... I also can't get the ICs off the heat sink.
      Any help would be greatly appreciated!
      //andy
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
