4659 Views 11 Replies Latest reply: Jul 2, 2011 1:45 AM by teki RSS
tnorris56 Just Startin' 2 posts since
May 20, 2008
Dec 26, 2009 7:01 PM
Splider Jam Unusable: Terrible Static and Pop
I purchased a Line 6 Spider Jam over a year ago and have nothing but problems with it.  Once the unit is turned on a static noise starts and grows louder and louder until a loud pop occurs. It will go away and re-occur constantly to the point you just want the shut it down and trash it. It is a real shame, because I purchased the unit for my nephews to play and jam with when they come down to visit and was looking at other high-end Line 6 equipment for myself.
Any one have any ideas what is causing this? The problem is definitely in the amp. The problem occurs without a guitar active.
Thanks.
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Dec 30, 2009 4:06 PM (in response to tnorris56)
    Re: Splider Jam Unusable: Terrible Static and Pop
    I would recommend that you re-install the flash memory on the Spider Jam to see if that will fix the issue.
    If the problem persists, you will need to take it to an authorized service center for repair.
    Regards,
    Line6Hugo
    • sandip666 Just Startin' 3 posts since
      Apr 5, 2010
      Apr 5, 2010 9:40 PM (in response to Line6Hugo)
      I have the exact same problem. Not sure what re-installing the flash memory means. My spider jam is about 2 years old, but it has never really been used.
      Do you have a real solution to this problem? I paid so much for this thing.
      I know the solution to any problem is to take it to the authorized service center, but that also means that I have to pay a lot of $$ to get it fixed, which I am not too excited about.
    Apr 5, 2010
    Apr 5, 2010 9:41 PM (in response to tnorris56)
    tnorris56,
    did you find a fix. I have the exact same problem, can really need your help. Thanks.
    • joegillespie Gear Head 795 posts since
      Mar 31, 2007
      Apr 6, 2010 12:32 AM (in response to sandip666)
      The noise and pop at switch-on are perfectly normal. It is the just DSP booting up. The memory is in a random state at switch on and until it is initialised, you just get 'white noise'. This should only last for a second or so. If you get these sounds at other times, there is a hardware problem.
      • Buy-a-Fender Iknowathingortwo 426 posts since
        Jul 25, 2008
        Apr 6, 2010 5:42 AM (in response to joegillespie)
        Have you tried a factory reset? if not give that a go
        here is what the users manual says:
        If you’d like to reset your Spider Jam to its factory-fresh state, discarding all your own adjustments to the User
        presets and restoring the factory-standard settings, do the following:
        Power up while holding the Tone / Settings
        button.
        Warning: a Factory Reset will replace all your customized User presets with the factory-standard settings.
        Flashing the firmware simply means you are reinstalling the embedded software that controls the amps functions.
        You can find the instructions and download link for this on the first page of this forum - look at the top of the page  for "Spider Jam 2.09 Update Instructions"
        If the amp is no longer under warranty I would open the amp up and check and tighten the ribbon connectors.
        If the amp is unusable - what have you got to lose?
        Joe Gillespie has a walk through on how to do this on his web site
        http://www.joesjamblog.com/fixes.html
          Apr 5, 2010
          Apr 10, 2010 10:23 PM (in response to Buy-a-Fender)
          Thanks Stevemason,
          I was skeptical at first, but I went through Joe Gillespie's process of opening the Spider Jam up and cleaning/tightening. Took me about 5 minutes...very easy. I did not find anything loose or anything that looked amiss. Nevertheless, I just blew the dust away and straightened up a couple of ribbon connectors away from capacitors (the cylindrical things) that it looked like they were touching. Whatever happened there, along with some prayers, did work. Once put back, the thing doesn't make any of the undesirable noise. Clear clean sound like it's supposed to make. I used it for about 2 hours and it was fine.
          Thank you.
  • lfigura Just Startin' 2 posts since
    Oct 26, 2010
    Oct 26, 2010 8:47 PM (in response to tnorris56)
    I am having the exact same problem.  I am so frustrated.  I will try the remedy above and cross fingers.
    • TimTheGrim Just Startin' 2 posts since
      Dec 22, 2006
      Nov 12, 2010 1:16 PM (in response to lfigura)
      I too have this problem. It started about 3 weeks ago and has been getting worse each time I use the amp.
      It has a 60 cycle hum like a bad ground and then as the volume of the hum increases and amp output volume goes down
      a crackle will start and then after about 20 seconds a loud pop will sound and then it's good for a few minutes and starts again.
      My amp has never even left the corner of my bedroom much less been gigged so I hope the fixes described above will help.
      How great is it to come to this forum and find this topic right near the top !!
      Thanks for all who shared.
      Tim
        Dec 22, 2006
        Nov 13, 2010 7:21 PM (in response to TimTheGrim)
        I took apart the amp following the instructions on Joe's Jam blog and found a loose ribbon connector almost immediately.
        I tightened it up and checked all the others as well.
        After reassembling the amp it is perfect once again.
        This took all of 25 minutes and was worth every second. Thanks again for this post and solution.
        Tim
  • teki Just Startin' 5 posts since
    Dec 25, 2008
    Jul 2, 2011 1:45 AM (in response to tnorris56)
    Does anyone know where Joe's Jam Blog went?  I have the same problem, but it seems that joesjamblog.com is no longer there?
    It is driving me crazy and I don't want to have to take it into a distributer.
    Thanks for any help in advance!
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
