2210 Views 2 Replies Latest reply: Dec 31, 2009 1:26 PM by PsicraftTony RSS
jpg006 Just Startin' 2 posts since
Jul 18, 2007
Dec 27, 2009 4:40 AM
Midi In setting for Vyzex
I am running XP with a Sound Blaster Live Sound card. Vyzex asks for both In and Out Midi ports. I have Midi out ports via Soundblaster and MS, but I do not have a Midi out port that I can locate.
1. Is there any other way to transfer settings from the Pocket POD to Vyzex?
2. Is there a solution to adding a Midi in port to my XP machine?
thanks
John
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Dec 31, 2009 9:00 AM (in response to jpg006)
    Re: Midi In setting for Vyzex
    jpg006,
    The only connection you should be using for the Pocket POD and Vyzex is through the USB Mini cable that comes with the device.  There is no need for additional MIDI IN/OUT ports.
    Please go over the following knowledge base document for troubleshooting tips:
    http://line6.com/community/docs/DOC-1382
    Regards,
    Line6Hugo
    • PsicraftTony Iknowathingortwo 243 posts since
      Jun 22, 2007
      Dec 31, 2009 1:26 PM (in response to Line6Hugo)
      Hi John,
      Hugo is right - Using the supplied USB cable is the only way to connect your PocketPOD to the Vyzex software.
      What you need to know is that by connecting this USB cable to your computer, the PocketPOD will 'appear' to the operating system (Windows or OS X) as a MIDI IN and MIDI OUT port in the program dialogs you are referring to. The software is configured to automatically open these MIDI ports and use them when it is launched, but if you don't have the USB cable connected these ports won't be visible and everything grinds to a halt.
      Let us know how it goes.
      Tony
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
