3021 Views 9 Replies Latest reply: Feb 8, 2012 6:28 PM by jdolphin134 RSS
NickDuggan Just Startin' 6 posts since
Dec 28, 2009
Jan 7, 2010 1:45 AM
Pod X3 Live caught in a reset loop
My pod x3 live is caught in exactly the same rest loop as noted in Gampguitar's post on 18-Nov-2008 (see below), and I could only get it going again the way they describe. Does anyone know how I fix the problem? Can it be fixed, or will I have to utilise the warranty and get the thing replaced.
Its totally messed up my gearbox connection, and I can no longer maniulate tones via the programme.
Thanks,
Nick
"..........Hello, I have got a POD X3 Live in which I have always set the presets using GearBox through the USB connection into my notebook computer. Whenever Line6 released the new version of flash, I updated my POD without any issues. On the last update, however, after the installation, an error in preset 20A occurred, and there was a very loud clipping signal which sent my amp into feedback. I’m not sure what caused it, but after it happened, my POD always initializes in a reset loop after the screen showing the Line6 logo (screen add in the last version of flash present in my hardware) and every time it initializes the CLIP red light turns on and off. Eventually, the message “UPDATE FLASH” showed up on the LCD screen, which I did.
Right now, I am only able to initialize in Safe Mode, and the situation hasn’t improved much. I have tried every single flash version, and I am only able to work normally with versions below 1.02. Any time I tried to upgrade the flash with newer versions, I get the same problem (initialization in a reset loop).
Has anybody had any similar issues? Is there anything I can do to get my POD working back normally?............"
  • ricksox UberGuru 11,641 posts since
    Mar 28, 2006
    Jan 11, 2010 4:13 PM (in response to NickDuggan)
    RE: Pod X3 Live caught in a reset loop
    Hello,
      I am sorry to hear about your POD failing. Were you able to get it repaired or replaced?
      Line6Miller
    Mar 28, 2006
    Jan 12, 2010 7:24 AM (in response to NickDuggan)
    Hello,
      Thanks for the follow up. Our Belgian support team are all good people so I am glad they worked with you to determine the unit was damaged. Let us know if you have any questions for us when you get your replacement.
      Line6Miller
      • GAMPGUITAR Just Startin' 6 posts since
        Nov 18, 2008
        Feb 21, 2010 6:09 AM (in response to NickDuggan)
        Re: RE: Pod X3 Live caught in a reset loop
        Hello guys! I'm GAMPGUITAR, the person that Nick has cited at the begin which has the same problem with the POD X3 Live.
        I'm not could resolve my problem also. The last version of flash memory that I could put in my POD fot it work was the 1.02 and I don't know why!
        In the safe mode the unique thing that seems not work fine is the MIDI and I don't no why also, I never use this!
        However, I can't use every others upgrades that Line6 launch after this version. I has to try update for new version 2.0 created now and the same happens.
        Please help me Miller, Nick could replace your POD because he was in the warranty period, I not. I have to pay for this. But this problem can happen with everybody at any moment, nobody knows what cause this.
        I don't make nothing that could broken my POD, this is a internal memory problem that appear!
        Please help me, what I do?
        • weswoodxxx Just Startin' 33 posts since
          Dec 9, 2009
          Mar 19, 2010 5:30 PM (in response to GAMPGUITAR)
          This has recently just happened to me. AFTER I got my pod back from a service center for the 3rd time (yes, they couldnt get the USB fix right the first 2 times, and ended up breaking it on the third attempt.) Anyways, All irritation aside, I would just like to know if theres any way I can get a replaced unit. Im tired of spending money and time trying to get my pod fixed. Once one thing works, another breaks. For a product that supposedly has impressive durability and gig ready hardiness, it sure is hard to get a pod that works correctly :/.
          Anyways, if any representatives could tell me what my options are at this point Id really appreciate it. I plan to call corporate headquarters on monday but just hoping there is a quick fix
  • aceshigher2 Just Startin' 6 posts since
    May 4, 2009
    Aug 4, 2010 11:54 AM (in response to NickDuggan)
    Re: Pod X3 Live caught in a reset loop
    im having the same problem , out of nowhere my pod x3 live just cut out and when i tried to restart it .. its doing exactally what yours is doing , did you find out anything about the issue ?
  • jdolphin134 Just Startin' 3 posts since
    Nov 12, 2011
    Feb 8, 2012 6:28 PM (in response to NickDuggan)
    Yeah sad to tell you I am having the same problem. Just wont start up. I tell you, I think I am going to delete my line six software sell my spider amp and move on. Its just wrong to be left hanging when thier is clearly a hardware defect.
    There should be a recall or something to fix these rigs they are not cheap (or are they?) Sorry we couldnt help is just not any help at all. In the future I will be sure to steer friends away from defective products and companies that supply them.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
