Jan 9, 2010 1:04 PM
FBV shortboard MKii (2) tap tempo/tuner button not working
Like (0)
Heya using a Flextone 3 with an FBV shortboard mk2 and the tap tempo/tuner button is very rarely working, on most occasions when i hold it down (for the tuner) nothing happens, and when i'm using any delay and tap to set the time once again nothing changes, the rest of the functions work perfectly, just updated to the new firmware as well and no luck, so either i'm doing something wrong or i have a hardware fault (unusual with these as far as i know)
The weird thing is it works occasionally, say once in every ten times i attempt to use either function
it's hardly been played as a result can anyone help please?
Not even sure that the MKII is compatible with the FLex3 series..
Will check and post back.
cheers but it is, http://line6.com/footcontrollers/compatibility.html
the rest of the pedal works perfectly and as expected it's just the tap tempo/tuner :s thanks though
murrayr,
The Shortboard MK II is compatible with the Flextone III series. I was also unable to duplicate the problems you describe.
There could be a problem with either the Shortboard or the amp, but will be tough tell unless you try either one with a different amp or pedal.
Also, make sure to check that the pins in the RJ45 jack of the amp or pedal are not bent.
You can also try resetting the amp to see if it will fix anything. Keep in mind that this will reset all presets to factory settings:
Press and hold the A and D channel buttons on the amp while you turn it on.
If the problem persists, you will need to take either to an authorized service center to take a look:
http://line6.com/service_centers/
Regards,
Line6Hugo
sorry for the delay in getting back, i have done all of this and i have tried it with a friends spider 3, and the problem persists, everything works apart from the tap tempo/tuner button, thanks for the help so the next step is getting it looked at ata service centre? thanks again for the help
Hello,
It sounds like your unit has a hardware failure and needs to go to service. Please contact the Line 6 UK team for assistance:
Line 6, Inc.
4 Sopwith Way
Drayton Fields Industrial Estate
Daventry, Northamptonshire
United Kingdom, NN118PB
Telefon: +44 (0) 1327 302 700
