2466 Views 5 Replies Latest reply: Feb 9, 2010 11:17 AM by Kneehow RSS
lmatos Just Startin' 5 posts since
Apr 23, 2009
Feb 3, 2010 9:36 AM
Problems installing GuitarPort Driver
Installed latest GearBox and Monkey.  Monkey says everything is up-to-date except for the USB device driver. Then I let Monkey update the driver.
It gets to the point where it says to plug in the GuitarPort into the USB port directly (no hub). Windows "New Hardware Found" wizard comes up.
I pick to install drivers automatically, but without searching for drives on the internet.  Installation begins and freezes on the file:  LG6PAsio.dll
The installation does not get pass this point.  Tried multiple times. Using Windows XP Professional, by the way.
If I kill the installation and try to run GuitarPort with GearBox, I get no sound. (Headphones plugged into guitarport line out).
The light on GuitarPort device is green. And the GearBox USB icon (bottom right) is not flashing.
However, I get no sound. There's no signal from the guitar into GearBox application.  Even the tuner does not recognize the guitar signal.
The guitar, guitar cable, and USB cable are good (tested in other equipment).
Any ideas?
Thanks
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Feb 8, 2010 11:19 AM (in response to lmatos)
    RE: Problems installing GuitarPort Driver
    Hello,
      In GearBox 3.70, is the Source Select set to: Instrument?
      Also, you're using headphones or powered monitor speakers connected directly to the output jack on the GuitarPort device, correct?
      Regards,
      L6Perry
    Dec 26, 2007
    Feb 9, 2010 11:17 AM (in response to lmatos)
      Ah yes, my fault. You have a GuitarPort USB device. You won't see the Source select option, please disregard.
      Next question: to double-check... have you tried connecting this GuitarPort to every USB port on your host computer? And going ahead another step, if you have a different computer available, what happens when connecting your GuitarPort? The reason I ask this last question; if the GuitarPort device itself is at fault, chances are that the symptoms would be the same if you use a different host computer. Having two completely different systems to verify the performance of the same USB device is the best way to make certain the issue is with the device and not the host computer.
      Let us know.
      Regards,
      L6Perry
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
