Line 6 - Support
5408 Views 9 Replies Latest reply: Jan 30, 2010 8:52 AM by robertthart RSS
howellnorfolk Just Startin' 15 posts since
Mar 22, 2009
Mar 26, 2009 8:55 AM
Line 6 Technical Support - Does it exist?
Does anyone from Line 6 technical support look at the questions on this Thread concerning BackTrack audio files?  I don't see any replies from Line 6 here..and I have a ticket that is still blank concerning the issues around why Backtrack files have no volume, why the auto-record function barely works with guitar input, and how you would use a pre-amp or an amp as an input to the Backtrack with no idea what the proper volume/gain setting should be.
Does Line 6 Technical support exist?
  • Line6Miller Line 6 11,613 posts since
    Mar 28, 2006
    Mar 26, 2009 12:47 PM (in response to howellnorfolk)
    Re: Line 6 Technical Support - Does it exist?
    It sounds like your BackTrack may not be functioning correctly but let's try a couple of things just to make sure.
    First, regarding your input signal from your guitar, have you tried adjusting the Guitar Input sensitivity settings in the BackTrack Utility software?
    Secondly, are you saying that when you play back files on your BackTrack that the levels are low? Adjusting the levels on the BacTrack does not effect this?
    Running from a pre-amp into the Guitar Input could potentially clip your input as the input is expecting an instrument level signal (-10dB) however, if you clip, just back off on the gain/level settings of your pre-amp a bit.
    Line6Miller
      • MGrd Just Startin' 141 posts since
        Feb 29, 2008
        Mar 27, 2009 4:23 AM (in response to howellnorfolk)
        howellnorfolk wrote:
        I have to ask: Have you ever actually used a guitar with a BT and tried to use the files  on  a computer?
        I can't help you with your problem and I'm not part of the Line6 staff.
        I'm using the BT since it's available and never had these problems when using the wav files on a computer.
        This belongs to both guitar recording and band recording via the build-in mic.
        If you configured the BT correctly and the problem is not related to you computer (unlikely), I think you should exchange the device at the seller.
            Feb 29, 2008
            Mar 31, 2009 6:55 AM (in response to howellnorfolk)
            How do you have the BT configured?
            Nothing special. I used the setup utility program shipped on the BT:
            - I've set the "Guitar Capture Preset" to "Elector Guitar/Bass".
            - The Microphone Capture is set to "Full Band" (or something similar).
            What computer program(s) are you using to listen to or edit the BT .wav files
            Every program capable of playing .wav files does it, really everything (Audacity, Winamp, mplayer ...)
            • holykashit Just Startin' 1 posts since
              Aug 16, 2009
              Aug 16, 2009 12:48 PM (in response to MGrd)
              I'm having the same issue as far as the sensitivity of the auto-record feature. I've downloaded the latest device setup app from Line 6 and tweaked it, and still all I get is a dull buzz sound instead of the raw guitar (and I have to strum really hard to get the device to detect the signal otherwise no go). If it's working for some people and not for others with the same settings, I assume it's a quality control problem. I'm going to exchange with the seller and hope i get a good one. Such a cool gadget, I will be really disappointed if I don't get one that works as advertised.
        Mar 28, 2006
        Mar 27, 2009 10:36 AM (in response to howellnorfolk)
        Here is the issue - When you use a guitar for the input to the BackTrack (a -10db input) the BackTrack creates a digital file. When you put that digital file into your computer - using Garageband, iTunes, Quicktime or whatever - the volume is too low to be usuable for anything..including just playing it back.
        I disagree here. I just recorded a riff on to the BacKTrack, Marked it, and dragged the WAV file onto an audio track into Ableton Live. Completely dry, the wav files measured about -11dB. This is right in the range you want to be (-12 to -10)      for a dry track considering most dry tracks will be re-amped later on with plug ins, outboard gear etc. See pic:
        The only way to get the volume level up is to put the instrument through an amp and take the line out of the amp to the BackTrack which you are correct about "Your Line Out is most likely Line level so it would be feeding the BackTrack a +4dB signal. The input on the BT expects an instrument level which is -10dB. It will work but you need to mind the level your feeding the BT from the Roland as to not clip the input on the BT." Most amps use the headphone output for the line out so you can no longer hear the amp. You then have to put headphones in the output of the BT to hear what you are doing.
        In order adjust the volume,  you have to record something, download it to the computer, see if the level is correct, and then record it again if its wrong. This defeats the whole idea of using the BackTrack for a spontanious recording.
        Again, I disagree. That's one way to do it but not the only way. Most recording applications offer ways to boost your WAV file levels if you want to. See pics before and after.
        Before:
        After:
        The guitar input signal (-10db) is often too low to trigger the auto-record function even when you set the auto-capture to "soft". If you do get it to work it will cut out if you play softly or hesitate at all while playing.  When you record using an amp as the input the autorecord function works better.
        There is no control in the BackTrack Utility for raising the volume of the input - there are only the controls for the auto-record sensitivity "soft" "medium" 'loud" but this has nothing to do with the volume of the recording.
        Well, not my guitar here. I'm using a 100 dollar Carlo Robelli beater that we abuse here in the office. The guitar is loaded with three strat style single coil pups. I had my BackTrack set to 'Soft" and it picked up my signal fine, even when I played dynamically loud and very soft. No problems.
        A lot of people on this thread seem to be having problems with this.  I have used Strats, LPs, Gretschs, Danelectros, Godins, Ibanez, and put the guitar volumes to the max and nothing will make a usuable sound level on a BT .wav file.
        This is true and possibly something we can improve in the future. I'd suggest submitting a feature request for this.
        http://line6.com/company/contact/productFeedback/?topic_id=3
        The manual for the BT says very emphatically:
        Make copies of the files on your computer to build up a library of inspiration, burn them to CD, convert them to MP3 to share them with your fans and collaborators. You can play them in your favorite audio software, and even load them into your recording software as a foundation for fuller recording of your ideas.
        No where does it tell you that the volume of the files created from your guitar are useless for any of these activities. And no where does it tell you how to work with that situation.
        Our manuals would never call out a function being "useless" but I understand if you weren't sure off the bat how to adjust audio files etc. Perhaps this is something we can consider in future manual revisions.
        The only other way to raise the volume of these files is with something like "Audacity", a free audio software package that has an "amplify" effect.
        But all of these work arounds for raising the volume of guitar generated files - amp out to BT, Audacity, etc defeats the whole idea of using the BT for spontanious recording - and basically makes the BT promotion quite fraudulent.
        If you want/need to raise the levels of the WAV viles captured then yes, you are correct, you'd need to route some other outboard gear in line with your guitar and BT or use software to adjust levels. However, as I've stated earlier in my post, the ideal range for a dry signal into a recording app is -12 to -10 which the BT caprtures quite nicely.
        Yes, I have used the BT and captured wav files and used them in recording apps. I love it. I think this thing is spectacular.
        Line6Miller
      • machinefish Just Startin' 53 posts since
        Aug 16, 2009
        Oct 30, 2009 5:32 PM (in response to howellnorfolk)
        I totally agree
        the .wav files are unusable on my pc.  Although they play back on the backtrack through an amp just fine.
        Im listening to the backtrack .wav files, which I can barely hear, and, quite suddenly, my computer screams at me, shredding the speaker fabric,
        "YOU'VE GOT MAIL"
        While my Hendrix impersonation bleats in the background.
        Awesome.
      • robertthart Just Startin' 1 posts since
        Jan 30, 2010
        Jan 30, 2010 8:52 AM (in response to howellnorfolk)
        That's probalby the root cause of the issue that I experience. When I strum very hard on my Takamine EG530SSC it wil start recording, but as soon as i take it easier or play fingerpicking on my guitar it just stops. Will there be a solution for this on short term? Or is it better to bring it back to the seller?
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
