Mar 26, 2009 9:06 AM
Pod Farm skipping amp model by itself in Pro Tools 8 ... ????
Like (0)
I'm having this very weird behavior with the lataest version of Pod Farm in Pro Tools 8. Each time I drag an amp, effect, or whatever model in the panel, it's not the one that I chose that shows up... And, on top of that, if I save the session with the preset that I want, close it and then reopen it, it's not the good sound anymore! It shows me the right amp and preset but it's processing the sound with another model...
I'm wondering what could cause this...
Anyone's experiencing this problem too?
Here's my setup:
iMac Intel Core Duo 2, 2.16Ghz, 2.5G Ram, Digi003R w/ PT8 CS.2, PodFarm 1.0.3 (PodXT license).
Thanks for the help...
First, please complete your System Profile here: http://line6.com/account/supportProfile/
What is the history of software installed on your computer?
1. Did you just upgrade to PT8? If so, what version were you at and were you able to run POD Farm (version ?) without the same behavior in your inquiry?
2. Did you have any previous builds of POD Farm software on this same system?
3. Do you have other Line 6 software besides POD Farm present? If so, what and which version?
Acutally I formated my computer and did a fresh install of everything, latests versions. I formated my computer bcause I wanted to go back to 10.5.5. I updated my OS to 10.5.6 and experienced a lot of bugs since this update. Could this be the problem?
Aside from Pod Farm I also have GearBox version 3.70
So after the OS reinstall you are still having the same problems?
Line6Miller
Actually, these specific problems started only after I formated my computer... I was having other kind of problems but not those. ![]()
OK. So what exactly is happening now? Are your current problems easily reproducible?
If so, can you provide me with a simple little step by step recipe so I can try to recreate your issue? Thanks!
Line6Miller
Hi there, I update my Pod farm to 1.10 but still i cant run it in Protools HD 8 cs2. it juz freeze n hang my mac 10.5.6 and i have to restart my mac
same as for the GearBox.
Dear Line6 pls solve it asap,I cant do my work with the amp.
