2416 Views 9 Replies Latest reply: Mar 17, 2010 5:21 AM by Colyn RSS
Colyn Just Startin' 5 posts since
Mar 5, 2010
Mar 5, 2010 5:25 PM
New Variax 705, should I upgrade Bass Pod XT? Also missing XPS DI...
Hi guys,
Long time Line 6 user but don't think I have posted here (well not in memory anyway!)
I had the original Bass Pod and now have the BPXT with the FBV floorboard.
As of today I managed to grab myself a 5 string variax bass (at a great price! still had all the tags/stickers etc on it, hardly ever played)
While I am all smiles, I have two questions for all you fellow low enders -
1) Is it worth getting the X3 Live over my current XT? (I like the idea of powering the Variax and switching patches, but have also read some compressor/limiter complaints and non frequency specific effects)
2) Any suggestions on where I could get a replacement XPS DI from? (I currently have an XPS Mini which powers the bass but doesn't have XLR out or ground lift etc) I realise this would be redundant if I got the X3Live but I would like to have the option to play without the X3Live as well.
Thanks in advance for any help!
  • david1_leslie Just Startin' 51 posts since
    Jul 27, 2009
    HI Colyn
    All these things come down to personal taste and what you need, but Im happy to share what I did and why.
    I like you tried to weigh up the pros and cons of whether to use the Bass Pod XT or the X3 Live.
    I also play in a covers band so versatility is the key for me it can be AC/DC one minute Stevie Wonder the next.
    Which is why I went for the Variax from using the Tobias for rock to the Synth bass for Nutbush City Limits, having a Variax Bass I believe is the way to go. They do appear to have reliability issues if you watch the threads and string volume has been a little up and down and the piezos appear to die rather too frequently, so there can be a down side. So to negate this I use my GAS (Gear Acquisition Syndrome) and bought a 5 string and a 4 string so I will have a back up. Touch wood I have only had the string volume issues and you can alter those through configuration.
    I found mine on Ebay and found a guitar shop that still have a new 705 so you are right if you want a Variax Bass you can find them. This is why I added the survey to this group to let Line 6 know there is still a demand out there (hopefully).
    The Bass Pod and the X3 Live have the same amps and cabs, and there are some known issues with the X3 Live around footswitches crapping out and the USB connection dropping out and being Made in China some have reliability issues. The Bass Pod offers a Biamping feature and with the X3 Live you get Dual Tones.
    If you do decided to buy the X3 Live I have seen some posts on that forum that say after a certain serial number a lot of those problems are resolved. I can't confirm whether that is right or not,
    I went for the X3 Live, the the main reasons were Dual Tone you can pull some amazing sounds with this but you have to put the work in. The outputs on the pedal I use are line signal out in stereo direct to the front of house using the XLR outputs on the X3 (these aren't on the Bass Pod) and then use my amp set flat just as a stage monitor so I can control the stage volume I have a Fender 80 Watt transistor amp using the other outputs for the stage sound (You can't do this on the Bass Pod and all in Stereo). It has a USB 2.0 and SPDIF connection for digital recording and I get all the guitar tones and effects for free some are useful others not.
    Personally I have found this works great and I am really happy with my live sound through the front of house, (while both of them do it) being able to trigger a different guitar in the Variax means you get the whole tone with one click of the foot switch.
    So I gig about 4 to 5 times a month from outdoor parties to pubs and clubs and have used my Variax 705 and X3 Live for the last 6 months trouble free. Also you get a great DI with the Variax Bass so if the X3 ever does crap itself self I would still be able to DI and keep going.
    So there you go my two bobs worth on that but I am sure there will be users that will have a different story.
    In regards to the DI I see them quite often on eBay, I have not asked but you could email Line 6 and see if they still make them and how much.
    David
  • neilwork Just Startin' 29 posts since
    Mar 5, 2007
    Hi Colyn
    Firstly congrats on finding a 705!!
    I love my 700 Variax Bass and can get sounds with it that are just impossible on a normal bass
    Such a pity Line 6 never followed thru with a Bass version of Variax Workbench though
    -would have been nice!
    Regarding your question about upgrading to an X3 my answer is most definitely!
    This is based on my own experience from performance and recording and most importantly
    the quality of sounds - not to mention the vast amount of tweakability possible
    with a dual-tone setup
    You will also notice a leap in the depth of sound and a higher studio quality with the X3 tones
    Any of the X3 models will give you this leap in tone - I owned a POD XT Live and as a bass player
    AND guitar player muddled thru with this
    I then moved to the X3 Live and was in heaven! Finally bass- dedicated cabs and amps plus vocals
    plus guitar!
    I was able to load all my tones from the XT Live straight in as a starting point for additional tweakage / expansion
    I found the bass presets in the X3 Live were what sold it for me - they are really powerful and a great platform to
    create your own sound with total recall ( including Variax programmability)
    I added to my tones by jumping on the Line 6 site and d/loading piles of great tones
    - thereby filling the X3 Live full of 128 diff. bass sounds
    As you know you can then back these sounds up and re- fill the POD up with 128 different sounds to suit your needs
    The X3 Live has possibly the best range of features out of the 3 models: Variax powering and digital audio
    plus lots of ins and outs for recording , DI etc.
    I had the X3 'kidney bean' for a bit and although the sounds were there the unit was a little
    hampering in that I had no Variax connectivity (and therefore could not tweak my V.600 in Wotkbench)
    plus no aux inputs or USB audio, so the choice was then down to the X3 Live or the X3 PRO
    The X3 PRO is mainly set up for studio useability (even though with an FBV you have essentially a souped-up X3 Live)
    -overall a really expensive road to travel if you don't need the AES/EBU i/o etc.
    If you need your sounds mainly for performance  and a little recording then def. go for the X3 Live
    -X3 Live also has Comp and Boost switches built in - very handy
    If you go for the X3 Live you will not look back believe me!
    Cheers Neil
    PS re the XPS: don't forget you also have battery option - I have powered my 700 bass this way for a live gig and 2 rehearsals
    so i got about 20 hours out of 1 set of batts and they're still going
        Mar 5, 2007
        Hi Colyn
        You may have a bit of a wait from Line  6 with parts but they will come thru!
        I have waited  for months for a new volume push/ push pot for my 700 bass
        only to be told they are not avail. but Scott & the great guys at Music Link are helping me out
        -they are supplying the whole pcb assembly as a swap out part instead!
        The Cat 45 jack may be easier to replace as it is a common part and you may not even need a Line 6 part on closer inspection
        -also rule out the cable first as the culprit - these can be bought easily
        All the best with your X3 Live!
        props to David for his wise words also
        - just another thought-  maybe we should this forum also to share our collections of Variax / POD bass sounds?
        (or has that been done?)
        Regards Neil
          Jul 27, 2009
          HI Colyn
          I feel your credit card pain, but I dont think you will regret the decision.
          I'm pretty sure the connector is just a standard Neutrik RJ45 connector which can be unsoldered and replaced. I have seen this one of the threads so some searching over in the general Variax forum might pay dividends as well.
          Might also pay to see if all the gold wires are straight inside the connector.
          Neil
          I think it would be a great idea to set up an area so we can swap tones for the Variax/X3 setup.
          I can't find any decent basstones in the Customtone, there may well be some there but finding them amongst all the guitar tones is impossible.
          I will check with Line 6 is there a way to better segment in Customtone, that we can just publish them there, and be able to find them again.
          If not will think about the best way of organising them on this forum.
          David
          • TJSher Just Startin' 4 posts since
            Dec 4, 2009
            David,
            I totally agree about the custom bass tone sharing thing.  Bass is really not well represented on the site.
            But I have recently fallen in love with the "complete package", which wasn't really complete until I got the Monkey and Gearbox software installed.  The Variax Bass with Pod X3 just isn't complete without the easily customizeable controls and additional sounds provided by the Gearbox software.  I put it on my laptop so I can make changes on the road.
            I've spent hours fiddling with it, trying to get the bass sound that the MUSE bassist uses on Hysteria.  I've discovered some great combinations,  I can get some nice fuzz sounds, but haven't been able to get a good synth sound like he uses.  If any of you guys have an idea how to do it, or want to take a stab at it, let me know.
            The software is so much easier to use than programming on the X3.
            Also, If anybody sees a Variax 705 bass hiding out in a store somewhere, please post here and let me know.  I've been looking to get a backup guitar for the summer show season, and I'd probably want to just get another Variax.
              Mar 5, 2007
              Glad I thought of it!
              I'm surprised no-one else thought of sharing here on the forum
              - i've got about 40 bass sounds to share
              regards Neil
