4783 Views 1 Reply Latest reply: Mar 16, 2010 2:33 AM by amx05462 RSS
Magiamusical Just Startin' 17 posts since
Nov 23, 2007
Mar 15, 2010 4:47 PM
Will the VDI Cable power the Variax 500 if the 1/4" is used
I'm working in a setup with a Gk-3 and GR20 and a POD XT Live.  The thing that apparently when the 1/4" cable it overides the power from the Variax/ POD XT.
I've seen setups using the power supply with the 1/4" input but I loose the changing of the Variax guitars sounds.  Any Ideas or comments?
This is my current setup:
  • amx05462 Power User 3,495 posts since
    Sep 1, 2008
    the gr 20 is powering the gk pickup  so its probably sending a bit of  power to the variax   throughthe  jumper cable also the pod is powering the variav through the rj45 cable.  your best bet is to   make up a small replacement cable from the  gk  with a stereo end on the  1/4 inch end   and leave the center section disconnected. i have that same gr 20  and the gk  but im putting  the gk kit in  nistead of the clamp on pickup so ill probably run into the  same  problem.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
