2715 Views 20 Replies Latest reply: Nov 27, 2012 6:39 AM by poynt99 RSS
abltsarr Just Startin' 16 posts since
Mar 10, 2010
Mar 31, 2010 9:11 AM
I got strange noise from amp simulations
If I turn down the amp sim the noise goes off. It's like an awful note that goes below the note I'm playing.
I attach an mp3 of that so you can hear it for yourself...
Please help me ASAP because I have gigs an I want to use my POD x3 Live!
Thanx.
      Dec 22, 2006
      Mar 31, 2010 10:28 AM (in response to abltsarr)
      Re: I got strange noise from amp simulations
      just an FYI....
      but you might want to list the amps that you are having issues with... that way someone can try them and tell you if its normal or not.
      i know that some of the modeled amps are "imperfect" and these imperfections are intentionally left in so that it sounds like the real thing and not some neutered digital "version"
      for the sake of your upcoming gigs... you might try different amps... afterall its really about what you hear... not what model you are modeling.
  • tbrisson Just Startin' 40 posts since
    May 31, 2009
    Apr 6, 2010 7:08 AM (in response to abltsarr)
    What you're likely hearing are 'ghost notes', these are artifacts present in the real amps that are being simulated.  There was a thread a little while ago here debating whether or not they should be included:
    http://line6.com/community/thread/29680?start=0&tstart=0
    FWIW, they are very noticeable to me when playing alone at bedroom levels, but not so much a gigging levels.
    Hope this helps,
    -Tim
  • ricksox UberGuru 11,600 posts since
    Mar 28, 2006
    Apr 7, 2010 3:49 PM (in response to abltsarr)
    RE: I got strange noise from amp simulations
    Hello,
      These are ghost note anomalies as mentioned by our other poster in this thread. According to our sound designers, these ghost notes exist in the actual amps that they modeled. So these are inherent in the X3 and there is nothing you can do to get rid of them completely.
      Line6Miller
    • poynt99 Just Startin' 32 posts since
      Jul 24, 2011
      Sep 9, 2012 1:03 PM (in response to ricksox)
      Re: RE: I got strange noise from amp simulations
      That's difficult to swallow.
      Further research into the so-called "ghost-note" issue has revealed that it is extrememly unlikely that these discordant notes are ghost notes modeled from the amplifiers.
      There are at least a dozen amplifier models in the POD X3 and Spider IV amplifier (and probably many more products) exhibiting this problem, and the suspicious fact that makes it difficult to believe these are modeled after the amplifier itself, is that every one of these models exhibits the exact same discordant note. One would expect each amplifier that was being modeled would exhibit its own unique-sounding artifact, yet this is NOT the case with these modeled amplifiers.
      Have a listen for yourself and come to the only logical conclusion available.
      PS. I have not yet listened to the POD HD, but I will report back what I find in this regard.
        Dec 22, 2006
        Sep 15, 2012 7:22 AM (in response to poynt99)
        well this post is 2 years old, and the x3 is 5-7 years old... it's safe to say it is what it is... for better or worse.
        i found that the ghost note issues can be more or less apparent depending on how the x3 is being amplified...
        meaning certain speakers or amplifiers tend to bring out the phenomenom more than others...
          Jul 24, 2011
          Sep 15, 2012 9:01 AM (in response to TheRealZap)
          Indeed, the X3 is an older, and in some ways, better unit than the HD. (I find the HD very "fizzy" sounding in comparison)
          Incidentally, I can not understand why L6 has not elucidated further on this so-called ghost note issue. 10 minutes after playing with the POD HD unit for the first time, I noticed the "HUM" parameter in the amplifier parameters section. When the HUM control is set to a minimum, the ghost note is eliminated, or at least reduced to the point it can not be heard. Who the hell wants more HUM in their tone anyway?
          So from this, it is evident that L6 added a 60Hz (or 50Hz) tone to modulate the amp'd signal to emulate what happens in some amplifiers with poor filtering. First of all it is ridiculous that L6 added this at all, and even more ludicrous that they provided no option to eliminate this in the X3. And as I already mentioned, it is even more surprising that they have not explained what is really causing the effect. In my opinion, several good amplifier models in the X3 were spoiled by L6's oversight on this.
          I have not yet tried this to confirm, but I suspect if the line frequency in the setup is changed from 60Hz to 50Hz, the ghost notes pitch will change also.
            Dec 22, 2006
            Sep 16, 2012 6:08 AM (in response to poynt99)
            HUM is a good thing... vintage amps had hum... it warms up the sound...
            sometimes you have to think in terms of a number of instruments... live or in a studio mix, hum can fill out your sound....
            its not always about the sounds of a lonely solo guitar.
            if the hum is what you are calling the ghost note issue... then you are also saying that the amps are authentic.....
            i prefer authentic to a sterile take on authentic...
            you also have to keep in mind that 2 of the same amps can sound different... they can be adjusted differently, have different tubes, biases etc.....
            Line6 picked out what they considered to be an amp that had a representative tone...
            they didn't "add" hum... they just didn't take it away where it already existed...
            they do allow this on the hd's...
            i also have to disagree about the x3 being better than the hd's...
            there are a few x3 features i miss...
            but sound quality isn't one of them....
              Jul 24, 2011
              Sep 16, 2012 8:59 AM (in response to TheRealZap)
              It comes down to opinion on the HUM issue.
              A great deal of effort and time, and devices (noise gates ring a bell) is usually spent trying to get rid of HUM. Why anyone would actually want to add it to their tone is mind boggling.
              The HUM IS what causes the ghost notes everyone on these forums has been complaining about. It's not a question of IF. The line frequency is modulating the signal going through the amplifier, and this modulation produces + and - frequency products. The ghost notes appear as these modulation products, and they are multiples of the line frequency and the fundamental frequency going through the amp from the guitar.
              Your preference to have these discordant notes present in your tone is noted, but I'm certain that if 1000 guitar processor users were polled to see if they wanted these notes in their tone after it was demonstrated to them what they sound like, 99% of them would say, "no thanks, I prefer my tone without these ghost notes".
              The HUM certainly was added. You can not cleanly remove something unless you added it in the first place. Sure, the amp they "modeled" may have had these ghost notes to some degree, but they didn't model that part of it. They simply added it as a modulation to the signal audio. That's why it can be adjusted in the HD.
              The same goes for the transfer function characteristic (amplitude out vs. amplitude in) of all the L6 amplifier "models"; they are essentially all the same. Listen closely to all the amplifiers, except for frequency spectrum differences, they all distort essentially the same way. L6 used one or two generic distortion curves throughout all the models, and placed them in different spots within the amplifier's signal chain. The frequency response of each amp is different, and that's why each amplifier sounds slightly different.
              On the other hand, if you listen to the Fender Mustang models, this is not so. Each amplifier has it's own characteristic distortion. That's why Fender has taken over a huge part of the modeled-amplifier market, and why the L6 guitar amps drastically dropped in price within the last year.
              Anyway, it all comes down to what sounds good to you. What ticks me off though is the manufacturers are much too often making choices for me on critical aspects of the design, rather than giving me the option to choose. And Fender is no better in this regard.
                Dec 22, 2006
                Sep 16, 2012 9:10 AM (in response to poynt99)
                they do give you the option to choose... on the pod HD units... they're not going to go back and reprogram anything older... just wouldn't be any money in it... and they are afterall a business.
                  Jul 24, 2011
                  Sep 16, 2012 9:37 AM (in response to TheRealZap)
                  I am aware of the option to remove the HUM in the POD HD. I did mention that.
                  BUT, most likely that only came about in the HD because of the prior user complaints.
                  Another example of what I meant by that, is Fender does not give the user the option as to where in the signal chain you can place the volume pedal. In fact until a few of us complained, the volume pedal would cut off the reverb trails because the volume pedal was fixed as the last device in the audio chain. How silly of a mistake is that? They've now partially corrected that by placing it after the amplifier, but there still is no option to place it at the front of the signal chain, where at least 50% of users would want it.
                  I appreciate that L6 got that part right.
                  • dennisrford Just Startin' 13 posts since
                    Aug 21, 2010
                    Nov 26, 2012 2:03 PM (in response to poynt99)
                    Thanks for the tip about lowering the HUM parameter to remove ghost notes.  I was ready to get rid of the HD500 before I read this.
                      Jul 24, 2011
                      Nov 26, 2012 3:43 PM (in response to dennisrford)
                      You're welcome Dennis.
                      L6 themselves should be letting folks know about this tip. In addition, they should be setting the HUM levels to zero by default.
                      They spoiled many useable amp tones in the "POD X3" with this silly HUM thing.
                        Dec 22, 2006
                        Nov 26, 2012 4:21 PM (in response to poynt99)
                        hum is sometimes good, and accurate for the amp modeled...
                        you don't like it... okay... then you probably wouldn't like the real amp... or you'd have it modified to not sound like the real amp...
                        hum isn't silly... if you take it out, then the sterile lifeless unrealistic remains can often seem cold and unusable to me....
                        and i could just as easily call that "silly"
                        it's ok if you don't like it... and some users didn't.... which is why they made it adjustable in the pod hd's...
                          Aug 21, 2010
                          Nov 26, 2012 9:15 PM (in response to TheRealZap)
                          All I can say is that I never heard a tube amp produce a noise like the HD500 did before I turned down the hum.  ymmv
                            Jul 24, 2011
                            Nov 27, 2012 6:39 AM (in response to dennisrford)
                            Although hum and the intermodulation it produces with the guitar notes is sometimes present in old amplifiers with failing filtering capacitors, it is rarely if ever a "good" thing. It's a clear indication that the amp's power supply needs refurbishng.
                            It has been said that some new amplifiers also exhibit this artifact, but like Dennis, I have never heard one, and I would challenge anyone to demonstrate one. I have a difficult time believing any amp designer would be satisfied with their amp sounding this way if it was meant for commercial sale.
                            RealZap, you have your opinion, and I have mine. I would bet however, that given a choice between two identical amplifiers tested side-by-side, one with the artifact, and one without, 99% of guitarists would choose to buy the amp without.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
