Apr 7, 2010 2:02 PM
[tutorial]HOW TO GET WORKBENCH WORKING IN 64 BIT! (and also in Linux OSes)
Like (0)
ok, I know how many people complain about line6 not making 64 bit drivers. I am one of the complainers, and it truely isnt fair. but, being the kind of geeky guy I am, I have come up with a workaround for getting varaix workbench to work in 64 bit, and even Linux!!!
Before We Start
you need a copy of windows XP. dont worry, you dont need to activate it on the net for this to work (though you will need an internet connection of course).
The Concept
the idea behind this is running a virtual machine. basically, a virtual machine is a program that acts as computer hardware. it allows you to run another Operating System inside your Host operating system. (many antivirus programs have a dumbed down virtual machine to test threatening exe's in a safe environment.) there are downsides to this, such as needing high midrange to high end computer hardware to pull this off.
What To Do
first things first. you need a virtual machine application. you can use many tools (such as virtualbox), but I find VM-Ware Player has the best USB support, so we will use it for this tutorial. you can grab VMWare Player for free from here: http://www.vmware.com/products/player/ (please note that registration is required. if the moderators here are ok with it, I am willing to share the installer file, but ONLY if the mods are ok with it),
once you have this installed and running, insert a windows XP cd into your disk drive, or locate an ISO image file of the CD. when you run VMware player, it will have an option to install an OS. obvously you use this.
when it comes to windows XP, VMware has a "quick install" feature, where you fill out info beforehand, and it runs through the installer quite fast. I highly suggest this mode be used. (be sure to give the VM a decent amount of ram. if you have 3 or 4 gb of ram in your pc, giving it 1 gb wont hurt.) once that is completed, be sure to install the "VMware Tools" into the virtual machine, from the dropdown menu "VM".
here is where the fun begins.
inside the virtual machine, go and download the variax workbench installer, and drivers. run through the installer as you would normally. next, plug your variax usb interface into your PC. cancel all the finding drivers stuff for your host os (because they wont work. its 64 bit, right?)
next,
at the top menu of VMware, click "VM", go to "removable devices", and enable "Line6 Variax USB Interface". this should disconnect your host OS from seeing the usb device, and make the windows XP Virtual Machine access the USB device, as if it were connected to a real PC. the drivers should install, and your variax should now interface successfully with workbench. I have tested this myself, without issue.
a few things to note:
once you have the VMware tools installed, you have the option to go full screen with your virtual machine, and you have the option to use "Unity Mode". Unity mode will close the windows XP interface, and intergrade it with your host OS seamlessly. in our case here, you will be able to have programs from windows XP working on a vista or windows 7 desktop. kinda cool eh?
I hope this tutorial is useful for frusterated users of variax work bench. be sure to leave me some feedback on how this went for you.
heres a few more screenshots for people who dont think it can be done.
I'll give this a try tonight. thanks a lot. I can't believe I didn't think of this!
no problem. most people dont think of this as an option, because they dont know that USB can be routed to it. I chose to do this tutorial with VMware (over my personal favorite, VirtualBox) because VMware has much better USB support.
If running Windows 7 Professional or Ultimate 64 bit, the Virtual PC route is equally as good for USB support in the virtual machine, so that's another possible option and you don't have to pay extra for Windows XP Pro as it's a free d/l from Microsoft pre-configured as a VM. You no longer need to have a machine that supports Hardware Virtualization either as of last month.
VMware actually works MUCH better then windows virtual machine, I find. it also offors more features, but you are right, it does stop the need for a windows xp license. not everyone has moved to 7 though (I'm still on vista with my audio machine).
I wasn't knocking what you have put together. I think you've done a great job. I agree that VM Ware is very good. No argument on that
I've used it.
Yep, Virtual PC doesn't support USB in anything earlier than Win 7 Pro and Ultimate and doesn't work in Win 7 Home Premium or lower so it's not going to be for everyone, but as a free alternative to VM Ware IF users have got a Win 7 Pro or Ultimate machine, VPC is viable as an alternative.
Nick
bonjour excusé moi mais j' ai windows vista 64 j ai installer vmware j' y es mis windows pro et line 6 monkey ne veu pas demarer il reste sur seaching for all devices ! et j ai rien compriscomment faire pour que monkey demare car j' y comprend pas grand chose en informatique merci
Bonjour. J'ai échoué à l'école française, donc je suis en utilisant le traducteur Google. il ya un bouton dans VMware pour permettre USB. regarde les photos que j'ai joint dans les postes de plus. il devrait être en vertu de la "VM" menu.
salut
ca fonctionne avec virtual pc !! tout les port usb sont reconnu merci ! je suis sous windows 64 mais c' est vraiment domage de faire marché workbench sous windws xp
pourquoi ce doit etre les utilisateurs qui doivent trouver des solutions et pas les concepteurs de produits ( line 6) ?
sur ce coup la c' est pas terrible , ca jete un froid sur les produit line 6 j' espere qu on aura pas a utilisé un amstrad 500 pour faire fonctionner les variax 2 james tayler lol !!
Brilliant solution. Works perfectly.
I was getting very irritated with Line6 NOT providing drivers.
Thank you!!!
hey, no problem.
unfortunately I get the feeling that line6 doesnt give 2 ***** about the variax customers who need drivers for newer operating systems. they seem to just want to bury the whole issue.
I found myself in a simular situation....coming up with a "workaround" for programming my Line 6 equipment in a Linux environment. I've used MickeySux Windows since its "incestuous inception" back in the 1980's and am all too familiar with everything that could possibly be wrong with it. Unfortunately.....Microsoft managed to force itself on practically every man, woman, child, farm animal, etc that you could imagine.
In short, I found a "quick 'n' dirty" sollution to getting Line 6 software & drivers to run within a Linux environment for those who don't want to spend their time chiseling away at programming their own Linux software. Sun Inc. used to put out a product called VirtualBox OSE (which lacked its own USB connectivity). When Oracle took over the Sun software, they revamped VirtualBox to include its own USB implementation. It's now possible to run a MickeySux Windows (or Mac"Donald's" OS) virtual environment from within a Linux OS, such as Ubunto, Mandriva, etc without much grief.
I won't get into all of the how-to's here, however I will suggest going to http://www.virtualbox.org, pick the version required for your flavor of Linux and play on from there. You will need some copy of Windows (or Mac"Donalds") to install in the virtual machinie environment (sorry to say), however you will be able to run your existing Line 6 software "as is" without much aggravation at all.
... may I suggest that you post the tutorial as a document, to make it easier for noobies (and others) to find.
Very positive contribution/dialogue.//Hats off!
JellyWheat
Sorry, I hate to be a wet blanket, but as far as I'm concerned this is not "workbench working in Linux". It's "workbench working in Windows, running within Linux". I'm not saying it wasn't nice of you to point this out as a workaround, and I'm not saying it isn't a necessity. I'm just annoyed whenever the only workable solution is to run Windows within Linux.
*sigh*... sorry, just had to get that off my chest. Carry on.
you have a very good point.
this software should run right period. you should not have to do all this workaround stuff. seems to me that every other piece of software you can get anywhere is pretty much self loading self setup. why workbench cant be that way is the fault of the programmers.
so you do have a very good point.
I think d3rocks deserved to be commended for publishing a fix that should rightly have been provided by Line 6. Why the company still thinks that their "ostrich approach" to known issues is satisfactory is beyond me! It's too bad, really, and the reason I have divested myself of all Line 6 gear... I will reconsider restoring my patronage when I feel more confident that it is, in fact, valued. I don't like their cloak-and-dagger approach to marketing.
[My $0.02 rant: If it weren't for the sheer genius of Steve Jobs, I don't think the market would have tolerated Apple's autocratic approach. Last I checked, however, neither Steve nor Woz were aboard Line 6.]
JellyWheat
this guy should get paid for making it work. after all the programmers at line 6 are getting paid. wtf is up with that. then again if the program was done right we wouldnt have to (make it work) it would work. but this is what happens when you have a monopoly.
I've been following the comments, and while I totally agree that having to use a third-party OS emulator is a "lame" way to get the resulta we want (namely manipulating our Line 6 gear in a Unix/Linux environment), for the time beiing, it's the quickest way around haivng to use MS or Mac machines exclusively. I've written software under Unix, Linux, Mac & MickeySux.....and quite honestly? The only reason anyone would write code in a Mac or MS environment is because it's "easy" so they can push their products out on the marketplace. Trying to get detailed spec sheets & hardware operating parameter info from a hardware vendor (like L6) is like getting daily root canals on all of your teeth.
I personally don't like the idea of running a Windows (or Mac) emulator under Linux to run software, however I have found that it does run faster since it's relegated to its own memeory space/allocation & is much less likely to crash or freeze up the PC. Some people have been writing & testing drives in the SourceForge.net open source forums, however without knowing exactly what the hardware will communicate with as far as software goes, it can be a totally "hit or miss" orgy & you end up hosing the hard-coded programming in your device(s).
With VMware Workstation 8 (and perhaps the newer VMware players) on a Linux host, you MUST remove the virtual sound card from the Windows guest before trying to install Line 6 Monkey and drivers! Disabling audio by any other means (VMware guest settings or guest tools) will NOT work. The virtual sound card apparently causes the Line 6 MIDI detect routine to trip over its own shorts. It will hang hard - to the point where it cannot even be killed with the task manager (never saw that one before).
Once all the drivers are installed, you can shut down the VM and reinstall the sound card. The Variax workbench and HD500 edit then seem to work fine even with the sound enabled.
It will almost certainly be necessary to go through this entire exercise again (shutdown, remove sound card, restart) before using Line 6 Monkey for firmware updates. Fortunately, that doesn't happen all that often.
I'm disappointed in Line 6 support who did not even offer a guess or any hints as to a workaround. Folks: You don't need to officially support this, but it probably would be nice courtesy to post a persistent message pointer to this thread to help others that might want to use VMware to run your tools.
