May 6, 2010 3:52 PM
Spider IV randomly going into Pitch Glide
Like (0)
Hello, I've had a strange problem a handful of times since I bought it new a couple weeks ago. My Spider IV 75W will jump into pitch glide mode, usually shortly after turning the amp on. Is this a known issue? It has happened with and without my FBV Express MKII attached, and also before and after I applied the Spider IV 1.52 update. Thanks for any help!
Hello,
No, that is not correct behavior for a newly purchased amplifier. You should get the amp to the nearest authorized Line 6 Service Center with a copy of your new product purchase receipt for them to diagnose and correct the problem.
http://line6.com/support/serviceCenters
Regards,
L6Perry
Will do, Perry. After some more fiddling tonight, I was able to reproduce a few more eccentricities, all related to Pitch Glide. Two amp models, Hi Gain Green and Insane Red, won't respond at all to the pitch glide adjustment with the FX knob. Also, when I use the FBV toe switch, it toggles between volume and pitch glide instead of wah for those two models. I can't get pedal wah to work with them at all. I've tried rolling back to 1.04 firmware and reinstalling 1.52 with no luck. I'll bring it to my local store to see what they can do.
