1679 Views 5 Replies Latest reply: May 30, 2010 4:38 AM by sliding_billy RSS
Angelus69 Just Startin' 3 posts since
Aug 21, 2007
May 26, 2010 9:28 AM
Can I Run Both an Analog and Digital Effects Loop in the Vetta II?
From what I understand I can run external effects processors not just from the analog effects loop but in the digital loop through either s/pdif or aes/ebu. I have a BBE sonic mazimizer already hooked up to the analog effects loop but i'd also like to run a TC Electronic G-Force. The G-Force has s/pdif connections and I just wanted to make sure before I just go ahead and buy one that its possible to run the digital loop (in s/pdif) and the analog loop at the same time. The manual wasn't as re-assuring as I would of hoped when describing the digital effects loop, does anyone know anything extra about its functionality. I'm running this set-up live just for the record...
Thanks
  • sliding_billy Just Startin' 97 posts since
    Jan 26, 2007
    You can only run the digital loop or the analog loop.  While they can both be connected at the same time, the digital will override the analog when turned on.  From the manaual...
    A setting of LOOP is used when you wish to connect to an external effect processor
    digitally. In this mode, the Digital inputs and outputs replace the analog effects loop on
    the rear panel.
    One word of caution on the digital loop.  the signal comes back to the amp L/R reversed.  Seriously!  This has been a bug since the VDI was released.  I am not going to beat the dead horse (well maybe a little ) , but I am the one that discovered it and reported it to the customer service manager however many years ago that was.  He didn't beleive me until he tried it while I was on the phone with him.  A fix was promised, but along with the other bugs that remain the L/R digital loop bug fix was abanded when Line 6 announced no further updates for the Vetta.  I know it sounds rediculous, but...  I have a G-Major so this is 1st hand experience.  If you want to test it, just use an RCA cable in the S/PDIF loop and listen to what happens.  Again, Line 6 already confirmed this as a bug to me.  The only possible workaround is to reverse wire your speakers and reverse program any effects that come AFTER the loop in the effects chain (thanks but NO) while always leaving the loop "on" (even when disabled at the effectes processor level).
    Chris
  • etherbrooklyn Just Startin' 17 posts since
    Oct 9, 2009
    Did you end up trying the digital loop with the Vetta?  I've been considering the same and wondered about your experience.
    (And thanks for chiming in on my questions re: the external cabs btw.)
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
