1334 Views 2 Replies Latest reply: Mar 15, 2012 9:10 AM by SjPedro RSS
wknow1 Just Startin' 4 posts since
Jun 1, 2010
Jun 1, 2010 3:05 AM
spider III with floor pod plus
is there any way to bypass the amp settings so i can use the pedal properly?
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Jun 2, 2010 3:39 PM (in response to wknow1)
    RE: spider III with floor pod plus
    Unfortunately, there is no Amp Bypass mode to use with the Spider III amp.  But you can try connecting the headphones output from the POD into the phones input on the amp to bypass the modeling.  (You may need to connect a dummy plug into the amp's 1/4" input.
      Regards,
      Line6Hugo
  • SjPedro Just Startin' 16 posts since
    Jun 4, 2008
    Mar 15, 2012 9:10 AM (in response to wknow1)
    Re: spider III with floor pod plus
    apparently there is a sort of a bypass from what I've read.
    The POT test mode of the Spider III.
    What you gotta do is hold the TAP button while powering on the amp. this will get it into a POT test in which as the name says, it's going to test the knobs and if they are working properly. Also the speaker will be close to it's higher volume possible and there will be no effects or anything going on. just pure signal. you can probably regulate the volume via the POD itself
    I don't know if this is entirely advisable though due to the fact that having the amp turn on so close to it's high volume..might brake something....I am waiting on my Floor POD Plus to arrive (a used one) to see what else we can do.
    Other two options would be connecting to either the Cd-Aux of the Spider which produces a similar result to the POT test mode or just dial in a clean setting with all the dials at 12 o'clock and the effects turned off (including reverb)
    Hope this helps!
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
