5374 Views 21 Replies Latest reply: Aug 2, 2010 7:48 AM by pletch5034 RSS
rmdnet Just Startin' 53 posts since
Oct 10, 2007
Jul 25, 2010 9:41 PM
FBV ShortBoard Pedal Not controlling Volume in full Sun
Extension of last reply to Line6 Miller's response to post saying to send to service.
Setup : FBV Shortboard with Spidervalve MKII HD100
We tried it one last time at an outdoor gig. Just in case we weren't doing something right.  It is most definately the sun playing havoc with the unit.  We put in in the sun, pedal volume did not work.  We ran through the resync process and after using toe switch and doing the min and max toogles on D switch, and the final test was quite unusual.  It stayed at Zero. No movement from 0 to 12x like normal.  When we move the unit into the shade it was able to work fine after the resync.  Tried that whole process again to be sure I wasn't crazy and the sun seemed to kill the volume pedal. This is brand new equipment that is still under warrantee so I guess I'l take it for service.  I'm wondering however if I end up with some refurb that will cause me more issues down the road.  We really need for a few gig in july (outdoors so hopefully they fix it fast).  Is that the only choice? Help
Problem Video
http://www.youtube.com/watch?v=rLPix_aJ7i4
  • pletch5034 Just Startin' 10 posts since
    Dec 27, 2009
    FBV Shortboard w/Spider VI 75w...Also played an outdoor gig in full sun on June 19 and had the same problem. After setting up, I found that there was no controlling volume or wah with the pedal. All other controls functioned properly. Tried changing the cable without any improvement. Thought the pedal needed to be sent for repair until I read this post. Set it up in the studio last night and it worked perfectly. Is there a fix for this issue? Tech seems to think the pedal uses a photocell for controlling and that being in bright light overrides the sensor. Glad it's working though.
                Mar 26, 2007
                Hi
                OK - maybe a bit of detective work on your part would help you in the short term.   You know what the problem is exactly - bright sunlight.   What you need to determine is exactly where the light is getting in, and although the answer to that might initially appear obvious, it may not be as obvious as you think.
                Number one place to look is the obvious - the hole inder the toe of the pedal where there is a piece of metal attached to the underside of the toe end of the pedal and which protrudes down inside the casing.  You can check whether this is the cause of the problem by jerry-rigging something to block the ingress of light around the hole just to test what happens with the pedal at different heights with the hole covered and uncovered.   I suspect this is most likely where the problem lies.  There is a foam ring inside the holewhich I think is supposed to help with this issue but it moves.  In my opinion, this problem requires a solution where the hole into the guts of the Shortboard is completely shielded.  A short length of thin but light tight compressible (concertina like ribbing) rubber tubing which covers the hole and is affixed to the underside of the toe end of the pedal would work and without impeding the travel of the pedal.  This type of rubber tubing can sometimes be found in the engine bay of modern cars on the ends of throttle or clutch cables or near door hinges in cars where it is used to provide flexible shielding for electric window, door speakers and electric door mirror wiring.  A trip to the local scrap yard might be in order.
                The second place to look and a less likely cause in my opinion would be the seams around the casing which may be a little more 'gappy' than is ideal.  My Shortboard is well made and doesn't appear to have excessive gaps in the places where the different metal panels are screwed together, so I would think that all Shortboards are built to similar standards.   But - you could use some gaffer tape to ensure that these are light tight if you think there may be a problem.
                I appreciate that you shouldn't have to resort to any of the above, but in the short term in the light of there not (apparently) being a fix, necessity is the mother of invention so you may have to be a little inventive/creative in finding your own solution until a fix is available
                Nick
  • GeeTah Just Startin' 110 posts since
    Oct 17, 2008
    Hey everyone:
    Well.... guess the FBVShortboard and the X3 Live use the same potentiometer for the foot pedal gain.
    Check this: Right now my X3 Live is in the shop due to the problem described in the thread found at http://line6.com/community/thread/38460?tstart=0 - basically oversensitvityto stage lighting. I bought an X3 Pro for my live rack and decided to go with the FBVShortboard MKII to control it. First show I used it (this weekend) a spotlight panned across me right when I had it muted (with the pedal), my tech was handing me another guitar and I plugged it into my body pack only the give the crowd a big BUZZ/BANG and I plugged into what SHOULD have been a muted line. The spotlight only came across me for a second (it just happened to be the exact second that we were changing guitars).
    Later one of our engineers checked out the pedal with a bright LED flashlight and panned across the hole in the pedal and was able to make the volume change even with the pedal rocked all the way back (supposedly muted). Same exact issue as the X3L...
    Guys what I believe we have here is a problem with the design of the X3L and FBV case in that it appears to be incapable of keeping light away from volume pot inside the board.... My FBV will be returned today...  but this is getting to be a drag. Really don't want to keep exchanging these.
    Maybe we need to come up with a really good and semi-permanent bellows for the hole that we can offer to everyone who is having this issue.....
        Oct 17, 2008
        Agreed on the Double Bummer! Definitely a shame. Really didn't want to have to connect an extra pedal to the board just to get it to perform basic duty (because of a malfunctioning main pedal on the board itself), but that's probably the best idea so far. I am taking the new FVB MKII Shortboard into GC today for an exchange (I have only had it a week and it came from the factory with this problem), but my guess is that this is a design issue, not a service issue. We shall see.....
    Dec 27, 2009
    Greetings All,
    I have made up a bellows type of shield to mount under the pedal, again similar to a bellows. I am playing outdoors again today and will see if this addresses our problem. I will post pix and description if it works. Still wondering why Line6 hasn't chimed in on this issue. An attorney friend thinks they may not want to deal with liability of the cost of a fix. Oh well.
    Pletch
      Oct 17, 2008
      Pletch:
      Will look forward to your design and the images.
      I actually posted a question on another area of the forum about an FBV controller we use with a rack-mount X3 Pro. It is doing exactly the same thing. We're pretty connected to Guitar Center and had them test a group of about 20 (5 here and 15 more at their warehouse in Kansas City) and they all were light sensitive. We just received one of our X3L's back from warranty repair for this exact problem and it came back with the same problem (even with a brand new PCB inside). So, to us it seems like a problem with the design of the unit, not its duty life.
      I guess it's OK if you play in your living room, but to be used in a pro setting where we have lights all over the place - moving spots, etc. it just renders the Line 6 volume controllers a "not road worthy" package... and I truly do hate that as it is the by-far the best sounding gear we've found in the price point (we are using 3 X3's now and have a 4th for a backup). The handiest thing for us has been to sync all of our X3's in Gearbox so that they all behave the same way. We used the Rocktron and TC Helicon systems before X3 and really like this system best (other than this one thing).
      Anyway, thanks much for helping this get worked out Pletch - hate to say it, but I really don't think  the guys at Line 6 are wanting to hear about it.... (like this thread being labeled answered and it isn't).  BTW, our workaround (so far) has been using gaffer's tape to shield the hole under the expression pedal from the light.....
      Rock on....
        Dec 27, 2009
        line6shield2.jpg here it is, used a length of wire from a hanger to form a frame and bent it so that frame snapped in under the pedal. will see if it works tonight.
          • lunagooch Just Startin' 1 posts since
            Mar 11, 2007
            I just wanted to add my experience with this issue. I played an outdoor gig last week in the bright sunshine. Later in the day large clouds would pass over and change the level of the guitar volume. The soundman asked my why the guitar level changed so much and I described to him what I had read in this thread.
            Folks, this is a bona-fide problem...not the imagination of just a few users. Definitely a design issue. Line6 tarnishes their customer service reputation by not acknowledging the problem...at least admit it!
            My thanks to those who are working out the problem with various gizmos...you'd think the manufacturer would help! Shameful and totally disappointing behavior from Line6.
            Where is the offical response from Line6!!!!!?
    Dec 27, 2009
    Hello All,
    The mock up of the bellows worked. We were set-up on a large stage facing the West on a very bright (and sweltering hot) afternoon. I set-up my rig and it worked flawlessly.
    I watched the video that was linked and see that the pedal can be removed without having to disconnect any linkage. I am going to try placing a material "tube" over the pedal rod where it covers the opening and see if this works.
    Funny I get responses and emails from Line6 to buy new gear, but have yet to get a response to our problem.
    Pletch
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
