2912 Views 12 Replies Latest reply: Sep 16, 2011 4:04 PM by Nick_Mattocks RSS
mtnman82 Just Startin' 112 posts since
Mar 15, 2008
Jun 20, 2010 4:56 PM
"No Line 6 device connected"...
I did some searching but didn't come up with anything...  I just installed Monkey & Edit on a laptop to take to my studio with the amp when trying to get a handle on setting up this amp for gigs (for some reason it's taking a biut more effort than the MkI did...).  However, I can't seem to get the computer to recognize the amp/FBV.  I'm running a fairly new Acer laptop (core 2 duo @ 1.2GHz), XP service pack 3, 2GB RAM, ...  The first few times I plugged the FBV in is showed connected to Line 6 something or another, now it just makes a noise when I plug it in.  When I start Edit, all I get is defaults and it says "No Line 6 device connected".  Can someone tell me the fix for this, or point me to a link?  Thanks in advance!
  • ricksox UberGuru 11,641 posts since
    Mar 28, 2006
    Jun 23, 2010 3:30 PM (in response to mtnman82)
    RE: "No Line 6 device connected"...
    Hello,
      Line 6 Edit won't work with your FBV MkII.
      If you want to dial in tones through the FBV MkII to your Spider Valve then download Spider Valve MkII Edit which you can download from http://line6.com/software/.
      Does Line 6 Monkey see your FBV Shortboard MkII when you connect it via USB?
      Line6Miller
    Mar 28, 2006
    Jun 24, 2010 7:27 AM (in response to mtnman82)
    Hello,
      Thanks for getting back to me. When you plug your FBV pedal into your computer via USB does the computer make a beeping sound?
      Also, after connecting the FBV pedal via USB go to your Device Manager on your computer and see if it shows up under Sound Video and Game Controllers.
      Right Click on My Computer>Manage>Device Manager>Sound Video and Game Controllers
      Also, have you tried all USB ports on your computer? Have you tried connecting it to a different computer?
      Line6Miller
    Mar 28, 2006
    Jun 25, 2010 7:26 AM (in response to mtnman82)
    OK. So it looks like the computer is recognizing the FBV. What about Line 6 Monkey 1.33? Does that software recognize the pedal?
      Let's just see if we can get the pedal to be recognized by wither Monkey or the FBV Control software first and then we can move on to adding the amp into the equation.
      Line6Miller
  • Styroks Just Startin' 9 posts since
    Sep 8, 2011
    Sep 16, 2011 9:17 AM (in response to mtnman82)
    Re: "No Line 6 device connected"...
    My Line 6 FBV control says the same, no line 6 device connected. And i also can't make the expression pedal do wah, it just does volume. How can i make it a cry baby?
    • Samzee Just Startin' 51 posts since
      Jun 12, 2010
      Sep 16, 2011 3:53 PM (in response to Styroks)
      I'm not sure about your Wah problem. Perhaps a firmware reinstall would do the trick. That seems to fix a lot of random oddities with the DSP. As for your connectivity problem, try it with no other USB devices plugged in. If that doesn't work, keep the devices unplugged, and open Device Manager. Right-click My Computer >> Properties >> "Hardware" tab >> Device Manager. Expand the "Universal Serial Bus controllers" tree, and remove all the items in the list. Start from the bottom and work up, right-clicking each and choosing "Uninstall." Close Device Manager and restart your computer. The point of this is to reinstall your USB drivers, which Windows will do automatically upon restarting. Sometimes the drivers can get corrupted and whatnot. Before reconnecting any other USB devices, try it again.
      Good luck.
    • Nick_Mattocks Expert Line 6 User 9,066 posts since
      Mar 26, 2007
      Sep 16, 2011 4:04 PM (in response to Styroks)
      Can you list the computer type, make, model, OS and any USB devices that have ever been installed regardless of whether they are physically connected or not.  The reason I ask is that I experienced the same issue in 2009 with the Shortboard and one of my laptops but only that laptop and not my other one.  the problem turned out to be an installed Logitech Web Cam driver even though the Web Cam itself was not physically connected.  The OS was Windows XP Pro in that instance.  Removing all traces of the Web Cam driver resolved the issue.
      The toe switch on the Shortboard can be hard to operate at first.  It does require quite a bit of pressure to make it switch and you do need to stand on the pedal.  Pressing by hand will not apply sufficient pressure.
      Nick
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
