1590 Views 4 Replies Latest reply: Dec 17, 2012 6:18 AM by fflbrgst RSS
ninch Just Startin' 4 posts since
Jun 22, 2010
Aug 18, 2010 8:59 PM
Error 80000002
Hello, I've got a FBV Express MkII. The item itself seems to work, as the system (OS X 10.6.4) sees it as MIDI device and also Guitar rig can bind some of its buttons. But the problem is that not all of them. The only actions that work are the pedal (both in wah and volume mode) and the A button. All other buttons do not make any sense, although MIDI monitor program says they actually send SysEx messages.
I assume that can be cured through reprogramming.
But FBV Control (1.03) software doesn't recognize the device, so I can't reprogram it.
Monkey (1.33) works strange – at the beginning it won't start without a device connected, but after opening the main window it behaves as if there's no device: it says that device firmware version is unknown, and if I try to update it I face a 80000002 Error in the end ("invalid parameter"). Even more, it reports device's ESN as "None".
Also the device itself refuses to enter calibration.
Looking forward to your help, thanks.
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Aug 20, 2010 11:23 AM (in response to ninch)
    RE: Error 80000002
    Yes, you should be able to reprogram the FBV to send MIDI CC's.
      The problem sounds like the FBV will not be recognized.
      Please remove all other USB devices (except a mouse/keyboard, and the FBV) while troubleshooting this problem.  Completely remove ANY USB hubs, even if not in use, and test the FBV Express Mk II on all of your computer's USB ports.
      Try a different USB cable just in case.
      If the problem persists, you should test on a different computer to isolate the problem.
      Regards,
      Line6Hugo
  • Sm4sh Just Startin' 3 posts since
    Sep 22, 2012
    Dec 15, 2012 2:39 PM (in response to ninch)
    Re: Error 80000002
    I had the same problem! But actually I've managed to work it out. I've programmed and updated the device on a PC (Windows 8) and used with Amplitube on the Mac (Snow Leopard).
    2 weeks ago I've bought the new Mac Mini!
    Turns out the FBV Express doesn't work anymore. It's dead.
    Anyone from Line 6 working on this problem?
    I read the same problem on a post of 2009...
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
