1841 Views 3 Replies Latest reply: Oct 19, 2010 10:02 AM by scott93933 RSS
scott93933 Just Startin' 33 posts since
Jul 5, 2010
Sep 29, 2010 9:15 PM
How do I get feedback without turning up my amp loud?
I have a Pod X3 Live and I love it. I regularly find new tones at CustomTone.com and use them for the cover tunes I'm playing with my band. The one effect I can't seem to get, however, is feedback. I realize that if I turn up my amp loud enough and get right in front of it with my guitar facing the amp I can get the desired effect, but being that my band and I will probably start playing clubs in the near future and I won't always be able to rely on my amp being in the same spot (I may not even have it with me if the club has everything there for us) or at a given volume, I can't rely on this method. But there are a lot of songs where it would be really cool if I could bridge the gap between the last note of a solo or last power chord before a bridge with some sustained feedback. I found a pedal online (the Behringer FD-300) that seems to do a decent job of it, but if I'm running my guitar through both this pedal and the Pod X3 Live, I'll be doubling up on the distortion, which would probably sound really weird.
With all of that background out of the way, here's my question:
Do any of you know of a way to get a feedback sort of effect out of the Pod X3 Live without turning it up loud?
If not, another possibility would be if I could just tap a harmonic on the 12th fret (or somewhere else on the neck) and get the Pod X3 Live to loop that high pitched sound for a few seconds before fading it out while I prepare to play the next guitar part. Any suggestions?
Thanks very much for your help!
   Cheers,
    Scott
  • grimm26 Just Startin' 303 posts since
    Nov 13, 2007
    Well, the POD X3L doesn't do looping and unless you have something like a sustainiac in your guitar, you need volume in order to produce harmonic feedback.  Getting that guitar feedback sound is actually an interaction with the amplified sound and your strings.  That's the reason that you need a loud amp in order to get the effect to happen - it has to be loud enough to actually affect the vibration of your strings.
    One assumes you'll have a monitor on stage for yourself even if your amp is tucked away in the back of the stage.  You can get your guitar to feedback from the monitor as well.
    • pchapple Just Startin' 126 posts since
      Apr 20, 2010
      Agreed.
      The only thing you could perhaps do to help the feedback to start would be to kick in your compressor at the end of the phrase to increase the volume / sustain and increase the chance of feedback at a lower volume, but it could sounds very messy.
      Alternatively boost the volume at the end of the passage by using the X3L footpedal, again to increase chance of feedback - also turning to face your amp help.  You could set the volume pedal range to 80-100% instead of 0-100%.  Normal playing volume is then footpedal full back and you can push full forward to increase volume / feedback.  Never tried it so may not work - just a thought.
      But basically you need the sound from your PA / amp to vibrate the strings of your guitar... ... all down to volume and gain/drive in your signal chain.
