1313 Views 2 Replies Latest reply: Oct 2, 2010 2:05 PM by dec33162 RSS
dec33162 Just Startin' 3 posts since
Aug 31, 2007
Oct 2, 2010 1:02 PM
Flash Upgrade Complete????
After successfully completing the flash upgrade (at least according to the onscreen message), Upgrade Complete.JPG
on a Bass POD XT Live, there was a final step that said to rotate the pedal from heel-to-toe until the WAH light illuminated after the click. This happened. It then said to rotate the unit back from toe-to-heel to switch back to volume.
I performed this step, but the WAH LED is still illuminated. No sound/click is/was heard to indicate the unit reverted back to the VOLUME setting. The AMP and Bank B LEDs were illumiated and the TAP Hold/Tuner LED is flashing. The Channel Memory Window initially showed 13.6 with the *VAR/MANTA Amp 23: California, Comp Amp and Date buttons selected. The Bass is currently not plugged in and other than the USB connection to the laptop, the only other connection to the Bass POD XT Live is power.
Upon reaching this step of writing, the Bank B LED is now "flashing" and the Channel Memory Window now shows 12.b Dub King Amp 23: California with Comp AMP and Date selected.
Unit will be left on for feedback before taking any further steps to ensure I don't corrupt anything. But please advise:
1. If something is wrong with the pedal that it didn't click and revert back to the VOLUM LED
2. Should I power down and reflash - (or can I since it has the latest version)?
3. Is the unit updating itself still, considering that teh Bank B LED is now flashing and my channel memory window data has changed without me doing anything?
4. What do I need to do from here?
  • Mr_Arkadin Expert Line 6 User 2,379 posts since
    Jan 25, 2007
    Oct 2, 2010 1:15 PM (in response to dec33162)
    Re: Flash Upgrade Complete????
    I would immediately try a re-flash. If you can't get it to re-flash try in 'Safe Mode' as described in this document:
    http://line6.com/community/docs/DOC-3827
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
