2870 Views 10 Replies Latest reply: Oct 5, 2010 11:56 AM by AsystoleJP RSS
AsystoleJP Just Startin' 6 posts since
Feb 9, 2010
Oct 2, 2010 6:32 PM
Problem Connecting 2 UX8s to a Single Laptop
Hello,
I recently bought a second Toneport UX8 so I would have more inputs to record in my practice space.  Both devices work correctly on their own, but I cannot have both running at the same time, one will install and the other will error out.  Is this problem solvable or is this just a shortcoming of the UX8?  If I can't get both working at the same time I'm going to have to return one and get a different interface to cover my needs, which I really don't want to do.  PLEASE TELL ME WE CAN FIX THIS?!?!    Thanks.
-- Joshua
  • Triryche Expert Line 6 User 3,698 posts since
    Feb 20, 2007
    Oct 4, 2010 7:10 AM (in response to AsystoleJP)
    Re: Problem Connecting 2 UX8s to a Single Laptop
    It is not solvable.
    Also, it is not a short coming.
    You can not run 2 audio interfaces at the same time.
    This not just with Line6 but with all digital audio interfaces, FireWire,PCI or USB.
    If you need more than 8 inputs simaltaneously, you will need a different interface.
  • ricksox UberGuru 11,600 posts since
    Mar 28, 2006
    Oct 4, 2010 2:37 PM (in response to AsystoleJP)
    RE: Problem Connecting 2 UX8s to a Single Laptop
    You wouldn't have been able to use them all at the same time without some sort of driver wrapper or something similar.
      Audacity doesn't use ASIO drivers so are you using something like ASIO4All?
      Tyriche is absolutely correct that you cannot use more than on ASIO driver simultaneously within a recording application within most, if not all recording applications.
      This technology exists for Macs with Core Audio in what they call Aggregate Device but not on PC.
      Line6Miller
    Mar 28, 2006
    Oct 5, 2010 11:53 AM (in response to AsystoleJP)
    Yes but that's expected. You can't connect two UX8's to one computer at the same time because they are both trying to use the same driver. Can't be done.
      Line6Miller
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
