3216 Views 11 Replies Latest reply: Sep 11, 2012 9:41 AM by jeffers777 RSS
stevoj Just Startin' 14 posts since
Apr 8, 2010
Oct 18, 2010 6:31 AM
Further M9 looper problems
Hi again,
I am re-posting this, as there has been no further reply to this issue in my previous thread
http://line6.com/community/message/183734#183734 (probably because I wrongly marked it as 'answered')
Here are 2 short loops to illustrate this ongoing problem, and I'll try to explain exactly which buttons were pressed.
Pt  1 was recorded with no FX.  A single chord is strummed once and the REC  button is pressed while the chord is decaying, and a short loop is made  by pressing the REC/ODUB button again.  I start adding some more notes,  and immediately press the REV button.  Everything I play from this  point comes out really distorted (listen 00:08 until 00:35). REV is  pressed once more, and everything overdubbed after this point seems to  replay OK.
Pt  2 was recorded with only a small amount of mild compression.  I tried  to reproduce the button presses, and although timing points are  different, the same problem does recur (distortion occurring in the  recorded data after pressing REV while still in OVERDUB. Then, after  pressing REV again, new layers are recorded normally).  At the end of  this track, I also pressed HALF SPEED so you can hear the distortion  differently.
Looper set to POST on both pieces.
btw, this fault is intermittent, ie, I can only occasionally reproduce it.
I hope this demonstrates the problem adequately.
Please let me know if this is a software bug, or whether I have a faulty unit.
Stephen
    Jan 27, 2010
    Oct 19, 2010 8:17 AM (in response to stevoj)
    RE: Further M9 looper problems
      Have you tried the unit with different cables?
      Also, have you tried a factory reset?
      Hold down the settings/tone button as you turn on the power and hold the button for 5-8 seconds.
      Thanks,
      David
      Line 6 Customer Support
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Oct 21, 2010 9:00 AM (in response to stevoj)
    Stephen,
      With your description, I was able to reproduce the noise on the overdubs.  Sounds like the overdubs are running through a ring modulator.
      Thank you for the reproduction information.  I will be logging this as a bug.
      Regards,
      Line6Hugo
  • mynameizbrian Just Startin' 4 posts since
    Oct 13, 2009
    Aug 17, 2011 10:57 AM (in response to stevoj)
    Re: Further M9 looper problems
    I see this is marked as answered and while I understand the issue has been found, it hasn't been solved.  I too am having this problem and I was playing out with the M9 pretty regularly and now it makes it useless to be able to do so, since I rely heavily on looping.  Has there been any update as to a fix for this problem?  I've been using the M9 since it released and made a lot of demonstration videos and talked the unit up a lot...and if this isn't a fixable issue that's going to be a big problem...
  • Currently Being Moderated
    May 2, 2012 2:08 PM (in response to stevoj)
    i also get this on my M9, it's almost a deal-breaker. please fix it soon!!
  • jeffers777 Just Startin' 2 posts since
    Apr 3, 2010
    Sep 11, 2012 9:41 AM (in response to stevoj)
    So another year goes by with not even a note from Line 6 to say yes or no on a fix? It's a crying shame
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
