11278 Views 14 Replies Latest reply: Jan 10, 2013 12:54 AM by djsnach RSS
AnnapolisBob Just Startin' 3 posts since
Feb 3, 2007
Oct 20, 2010 7:41 PM
POD HD500 - Factory Presets List
Is there any document that lists (and/or describes) all the factory presets that come with the POD HD500?
    Mar 26, 2007
    Oct 21, 2010 2:46 AM (in response to AnnapolisBob)
    Re: POD HD500 - Factory Presets List
    If you look back in this forum to about 2nd October someone asked for a list of the factory presets.  I posted at that time what was showing in my HD500 all 256 presets, however at that time a couple of the presets were listed in my device wrongly.   I did intend at some point to go through them and add the amp model and FX used as a table, but that's a big job really, and I simply haven't had time with my day job, life in general and actually using the HD500 to do it.
    Do you have the HD500 already?  If so you might find the Set list I posted last weekend useful as I've set up a basic preset with common FX (all OFF) in it once and then added an amp model and copied the preset four times and adjusted the gain and channel volume accordingly so for that amp model with everything except Drive and Ch Vol controls set at Factory Defaults there is a Clean, slightly Dirty, Crunch and Solo setting over four presets in a bank.  I then repeated exactly this but changed the amp model for each bank for the next 15 banks so you have all 16 amps with the same FX chain and you can audition each amp easily and even use the presets as the basis for making your own by tweaking. Here's my set list link: http://line6.com/community/thread/46526
    As far as finding a full descriptive list of all the factory presets - I don't think one exists.  If you go to Custom Tone you will find over 129 presets designed by users (some are mine such as they are) and there are descriptions for some of them but not all.
    Nick
    • ozbadman Gear Head 1,474 posts since
      Apr 17, 2008
      Oct 24, 2010 11:43 AM (in response to Nick_Mattocks)
      Hey Nick,
      That was me who asked for the list before I got my HD500 (thanks again for doing that BTW). I also posted my upload of the original presets bundle that came with my HD500 (after 1.1 upgrade) to the link Nick mentions above so you can load that into HD500 Edit and look at the presets (for v1.1 firmware) yourself.
      Cheers,
      David.
    • SStiv Just Startin' 68 posts since
      Feb 22, 2007
      Oct 24, 2010 7:38 PM (in response to Nick_Mattocks)
      Nick,
      Thanks for that by the way. I found it very useful.
    • bclarke675 Just Startin' 153 posts since
      Jan 24, 2007
      Oct 26, 2010 7:20 AM (in response to Nick_Mattocks)
      I don't have a POD HD500 yet, but am considering trading my JM4 Looper for one.  I was just interested in the names of the presets to see if they emulated any of the tones in my JM4.  I'm aware they may not feature song names, but perhaps give clues as to artists or songs they may work for?!?
      If anyone has such a listing, can you please post or direct me to the prior post.  I find this forum VERY difficult to navigate or search compared to others I've used.
      Thanks,
      Bob
        Mar 26, 2007
        Oct 26, 2010 9:24 AM (in response to bclarke675)
        Bob
        Here you go: http://line6.com/community/thread/45222
        Bear in mind that the list of presets shown in the list were the ones that were in my HD500 at that time and there are a couple that are incorrectly listed.  However, the factory preset names are in general a little ambiguous, but you will spot the odd intentional if somewhat ambiguous nod in the direction of a song, style or artist, such as Irish Tour - vaguely pointing at the late, great Rory Gallagher, Fish Rising as a nod of respect towards 1970's prog rock guitarist Steve Hillage and Dutch Pasadenian which nods in the direction of the great EVH, but don't necessarily expect these tones to sound exactly like any of the artists mentioned but the inspiration behind the tones is sort of evident.  With regard to any of the factory presets you might think they're good, You might think they're not so good, but the point of the majority of them in my view is to demonstrate various aspects of the HD500 and different ways in which the signal can be routed, so I'd treat them in some ways as a learning aid rather than the be all and end all.  You'll find quite a few user presets up on Custom Tone which might be closer to what you want.
        Nick
          Jan 24, 2007
          Oct 26, 2010 11:25 AM (in response to Nick_Mattocks)
          Thanks Nick!  That helps a lot.  Still not sure I want to trade, but I've heard that the effects on the POD are far superior to those on the JM4.
            Mar 26, 2007
            Oct 27, 2010 8:29 AM (in response to bclarke675)
            Bob
            You might find my organised set list with all the FULL amp models highlighted of some use,  which is simply all 16 of the amp models largely at default settings except for Drive and Channel Volume controls so that each bank of four will contain approximate default settings for CLEAN. SLIGHTLY DIRTY, CRUNCH and SOLO with the differences being Gain and Channel Volume.
            For no other reason other than it seems to make sense to have some basic FX in a preset, there are the basics like Wah, Volume, Distortion, Modulation and Delay not particularly configured for anything - they're just there at their defaults.  I've left all the FX in the OFF state as the default except in some cases in the SOLO preset at D there may be a noise gate - but this doesn't apply to all the presets in the D position in each bank.
            The presets in all the D slots are intentionally louder as they would fulfil a SOLO role, so keep your speaker levels at moderate to quiet settings until you get a feel for the levels involved
            These presets don't pretend to be anything other than what they are - a means to try out all the amp models.  If you find them useful, great, if not, so be it LOL, but several users have said they've found this set list useful.
            Factory presets are again what they are, and I tend to view them more as a learning tool or a foundation rather than something I would necessarily use myself in a live situation and in that respect there are some pretty neat ideas in them which you might find useful or fun.  There are now nearly two hundered User designed presets up on Custom Tone for the HD500 which will vary in style, volume and accuracy no doubt, but it is a very good resource nevertheless.
            If you are unhappy with the different levels in some of the factory presets it is a very easy task if somewhat tedious one to go through them all and level them yourself before saving them in their original locations.  The newly 'levelled' presets can be saved as set lists like mine above and be uploaded here for anyone who wants them, but to be honest and in my opinion it's probably as easy to leave them as they are and just to have a listen to them and see which if any you might like, and just take those you might find useful as a basis for your own presets
            Best regards
            Nick
            • whiteop Just Startin' 415 posts since
              Dec 5, 2009
              Oct 27, 2010 4:17 PM (in response to Nick_Mattocks)
              there are some jewels among the bunch but I have to keep my fingers on the master level knob when I change to each new patch if you know what I mean...lol
              BTW I appreciate your help and insight here on the forums a lot. Line 6 does a much better job monitoring their forums and assisting people than any other websites that I know of. It was a definite factor when I bought the HD500 after having a positive experience with an M9 that I purchased that had a volume drop problem with the looper. Rather than make excuses for it they tried to help me resolve the issues. You dont' find that type of service everyday.
                Mar 26, 2007
                Oct 28, 2010 1:20 AM (in response to whiteop)
                LOL
                Yes - quite possibly you need to ride the fader as you switch.  It was a fairly quick job I did and with limited levellling as I just wanted to put the amps in an easily accessible order in a set list with the settings as close to defaults as possible.   If there are jewels in there, it's not down to me.  Those are the Line 6 amp models doing it just on their own.
                Regards
                Nick
    Dec 5, 2009
    Oct 27, 2010 7:56 AM (in response to AnnapolisBob)
    when you go through them be prepared to turn the volume of many of the patches down as some might be able to blow your speakers. Some are much louder than the others which doesn't make sense to me. I've never seen a collection of patches with so many different volume levels in my life. What was Line 6 thinking? They don't appear to be very organized either. It's like they let a bunch of teens tweak the knobs and invent new patches and save them. When a new update is made it would be nice if the volume levels of the stock patches were levelled out a little more.
  • hootenanny Just Startin' 11 posts since
    Jun 14, 43430
    Jul 12, 2011 2:09 PM (in response to AnnapolisBob)
    Has such a list been compiled?  I do not know enough of the vague references to which the preset titles allude.  It leaves me wondering who or what a preset is trying to emulate.
    I need some education on what effects and amps are supposed to sound like or accomplish.  The "POD HD Model Gallery" is good but I need more of it.  Are there any good websites or tutorials out there?  POD HD specific or not.
    Jerry
  • djsnach Just Startin' 3 posts since
    Oct 10, 2011
    Jan 10, 2013 12:54 AM (in response to AnnapolisBob)
    Hi guys, can you help me. I need sound like
    Soundgarden - black hole sun - intro solo guitar
    for my Line 6 HD 500
    thank you
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
