8468 Views 4 Replies Latest reply: Aug 19, 2012 1:50 PM by hakvard RSS
karimba45 Just Startin' 2 posts since
Oct 26, 2010
Oct 26, 2010 8:45 AM
DL4 power supply
Hi all,
I have just bought a brand new DL4 delay unit to finish off my pedal board.
I have a dunlop power brick and when I went to plug the power in it wasnt compatible.
It appears the male part on the pedal is slightly bigger that the femail power brick would accept.
Stupid question, but can I try making the hole bigger on one of my adapters, or is it a totally different power requirement and hence I need to buy the power for it?
Any help greatly appreciated
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Oct 26, 2010 4:34 PM (in response to karimba45)
    RE: DL4 power supply
    Hello,
      Please don't modify your existing power adapters...
      The DL4 requires a power supply that can provide 9 volts of "AC" (not DC like most pedal effect power adapters!) power with at least 1500mA of current. You probably won't find too many power supplies out there that will fit the bill, so we always recommend that you stick to using the Line 6 "PX2" power adapter, as these are designed to provide the correct power voltage and current requirement our POD's and DL4's require.
      Regards,
      L6Perry
  • hakvard Just Startin' 1 posts since
    Aug 19, 2012
    Aug 19, 2012 1:50 PM (in response to karimba45)
    Re: DL4 power supply
    Most power bricks comes with different kinds of cables and voltage opportunities. I had the same problem as you had when my DL4 started blinking wich is a sign of low battery, but i found out that the blue cable that came with my FuelTank fitted into the DL4! What a lifesaver.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
