4014 Views 15 Replies Latest reply: Apr 15, 2011 8:21 PM by jeffk4478 RSS
ancientalien Just Startin' 20 posts since
Oct 19, 2010
Oct 26, 2010 12:01 PM
Connecting the HD500 with 4 cable method?
I wanted to be able to hook the HD500 up to my head with a 4 cable method to utilize the effects properly.
I want to be able to assign pedals like Phaser, Wah, OD, Volume etc to the input of my head.
And at the same time be able to use the delay and reverbs etc thru my loop in my head.
Is this possible?
Or will I be re routing my stomp effects in front of the head back into the loop?
Any help on setting this up would be greatly appreciated.
Thanks
    Mar 26, 2007
    Oct 26, 2010 12:10 PM (in response to ancientalien)
    Re: Connecting the HD500 with 4 cable method?
    Hi
    You can use the 4 cable method with no problem.  You place the FX loop anywhere within the signal chain like you do with the M13 and those FX pre the FX loop will go into the front of your amp whilst those after the loop will be in your amp's loop if you want to do it this way.   However, personally, if I were you I would check out the amp models in the HD500 before you definitely settle on having to do things using the 4CM because the amp models are what makes the HD500 and the 3/400 units shine and i would recommend that you go in to the amp's power amp alone for most of your presets.  The good thing though about the HD500 is that the FX loop is a per preset setting, so for some of your presets you can effectively go 4CM whilst with others where you don't want an FX loop effect block in your presets you can easily bypass the front input of your amp without having to change your wiring setup so you get the best of both worlds
    Nick
        Mar 26, 2007
        Oct 26, 2010 12:37 PM (in response to ancientalien)
        OK - I see what you want to do.
        Using your example, set up your preset(s) as follows in the HD500 Phase, Wah, Volume, FX LOOP, Delay, Reverb, Chorus. make sure you have the amp models set to OFF.
        Assuming your amp has a serial FX loop your cable routing is as follows:
        GUITAR > HD500 guitar input
        HD500 FX Send > AMP Front input
        AMP FX Send > HD500 FX Return
        HD500 Output > AMP FX Return
        The HD500's FX Loop is capable of stereo on TRS patch/'Y' cables if you want to use two amps in a stereo configuration BTW with some slight modifications to the above routing
        Nick
            Mar 26, 2007
            Oct 26, 2010 12:59 PM (in response to ancientalien)
            You need to try the amp models though if you haven't already - they are pretty good - the best yet in any of the three previous PODs (2.0, XT Live and X3 Live) that I still have.  The routing options are pretty flexible - they don't have to be exactly as I laid out in the example with the HD500.  The HD500 with one of the new DT50 amps is another story too - well worth trying if you get the chance.
            I was tempted to say 'why not just get an M13?' if you don't want to use the amp models in the HD500, but i think you will find out all sorts of fun stuff and different configurations as you become familiar with the HD, so enjoy
            Good luck with your rig
            Regards
            Nick
                Mar 26, 2007
                Oct 26, 2010 2:05 PM (in response to ancientalien)
                I'm an old fart too LOL, but seriously I am so impressed with the quality of the HD500's models and it is not quite so clear cut in reality as perhaps it used to be when it comes to recording.....
                • cGil Just Startin' 393 posts since
                  Jun 5, 2007
                  Oct 26, 2010 4:11 PM (in response to Nick_Mattocks)
                  Ditto on the old phart thing (only 57, but already getting AARP ads), and ditto on the incredible detail of tone in those models.   And ditto on the multi-purpose nature of the HD500!    This thing really will stand very well on its own as a one-pedal-does-all solution.   4 cable method with a loop in the amp?  No sweat.   But the models are SO GOOD that the HD500 is equally suited as being the only tool needed between the guitar and a mixer board or computer.  Or between guitar and the front of an amp without a loop.    Or between guitar and straight up rack tube amp.  Or with headphones for late night noodling.  Whatever!  It'll do it!
                  Finally we have the right tool to do ALL those jobs superbly.   There is, however, a dark side what with these models now being closer than ever to the feel and tone of genuine hot tubes.   Is this covered by Murphy's Law?   Maybe we should stock up on tubes before the modelers kill the tube market, closing the few remaining tube factories down, and driving tube prices into the stratosphere?   Hey, I still love my tubes.  Even if it's soon to be just an old phart thing.
                  Gil...
    • jpage1974 Just Startin' 2 posts since
      Feb 26, 2009
      Dec 10, 2010 11:13 AM (in response to Nick_Mattocks)
      Hi ,
      This is my first time posting to the Line 6 forum so forgive me if I am doing it wrong (asking a question in the "wrong place").  I am trying the Four cable method as an option with my new HD 500.  I do appreciate the amazing HD amp sims.  They are great!  But- sometimes I want to hear the sound of my new Blackstar HT-5 come through a bit more.
      My entire set up is brand new; HT-5, Line 6 HD 500, and even new Evidence Audio Lyric HG cables.  I have never had a floor effects unit before or uni-directional cables.  My question is:
      What way are the cables supposed to go in to the HT -5 head effects loop send and return, and HD 500 unit?  Do the "arrow" ends always go to the "receiving" part of the chain?  I have heard that you don't have to use unidirectional cables unidirectionally but that it is optimal.
      Thank you for your help ahead of time!
      Jon
  • jeffk4478 Just Startin' 5 posts since
    Aug 4, 2009
    Apr 15, 2011 8:21 PM (in response to ancientalien)
    i did that with my x3 and my hafler triple giant preamp and i'm pretty happy with it.  I'd hesitated because it seemed kind of blasphemous to let the x3 run the show with the giant in the effects loop but it's better that way.  If you have any type of preamp, or amp with an effects loop,  it's the only way to use the amp and have the effects in the right place (wah before the amp, reverbs after...).
Bookmarked By (1)
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
