Oct 28, 2010 5:57 AM
Variax power problem
Like (0)
I have been playing my Variax 500 for about 7 years now and have always absolutely loved it. I have always used it in conjunction with my PODXT Live and have NEVER had a single problem with either unit.
Two days ago I bought a new amp and wanted to play through it without the POD, so I plugged my Variax into the supplied power box (XPS?). It worked great for about 30 seconds and then it started popping and the red light started flashing. I immediately powered down and unplugged everything.
NOW, when I plug into my POD, the POD won't boot at all. I have to unplug the Variax to get the POD to boot and then plug it back in. The guitar is still being powered by the POD, however, the POD is no longer funtional...can't change banks or sounds...nothing. If I unplug the Variax the POD works fine.
How can I resolve this situation? The Variax is the only guitar I currently own and I can't play with this going on!
THanks.
Gina
Do you have batteries installed in your Variax? If so, take them out.
No, I have never put batteries in it. LIke I said, I ALWAYS used it with the POD until the other night when I used the TRS cable to plug it into the supplied power box.
In the words of the famous gladiator, Variax Problematicus:
Ɠ8>ᵆ}..."Tabula materna fortasse concremata?"
One hopes not... perhaps amx05462 will shed some light on this for us....
JellyWheat
it defenitly sounds like you did some damage to the guitar . the pod or the xps should bot supply the same amount of power to the guitar.
my question would be is the power supply for the xps a line 6 power supply ? if not that may have caused the problem.
the line 6 power supply that i have puts out 9 volt ac at 2000 ma or 2 amps.
if you have a different one it could have fryed a resistor. the thing to do would be to open up the guitar and check the boards for any burnt components. if the guitar functions with batterys correctly look in the area of the trs board and the vdi board for burnt stuff.
... sapebat, quid juvenis ingeniosum, sapebat !
Ego te saluto
J-W
