8519 Views 15 Replies Latest reply: Jun 7, 2011 5:14 PM by Ignacio108 RSS
dftpunk Just Startin' 112 posts since
May 20, 2007
Oct 30, 2010 3:17 AM
POD HD500 + Microphone
Guys I have another questions to you:
POD HD500 has a microphone input and I know that I can connect mic via this input and control effect "talkbox" effect, right?
Here's first question: can I setup talkbox the way like vocoder so my voice will be like in songs of Kayne West? Do you know some videos on youtube concerning "talkbox" in POD HD500? Does talkbox the only effect which could be controlled by the mic?
Here's another question: Can I sing through POD HD500's amps/effects using mic input? Can I sing and play guitar simultaneously or such feature available for X3 only? Can i separate outputs and got vocal from XLR output and guitar through 1/4" output?
Thank you in advance!
    Mar 26, 2007
    Oct 30, 2010 3:27 AM (in response to dftpunk)
    Re: POD HD500 + Microphone
    Hi
    The HD500 does indeed have a mic input.
    The HD500 currently includes amongst its effects a Vocoder so you're in luck
    You can certainly use the mic input with any of the FULL or PRE amp models and any of the FX as part of a single or dual signal path setup and so send the vocal out of one output and the guitar through another although currently the XLR outputs mirror the 1/4" outputs - panning L an d R will separate the signals though.  I hope that more output options will become available at some point in the near future.  The HD500 does not include any vocal specific amp or preamp models currently, but this is not really an issue as you can use no amp model if you wish and get a good sound using EQ and FX or you can use one of the 'clean' guitar pre-amp models and it will sound good.  Many of us are hoping that moreamp models will become available in some way in the future
    Nick
        Mar 26, 2007
        Oct 30, 2010 5:10 AM (in response to dftpunk)
        In the System Setup pages you can choose what goes in to input A and input B on a per preset basis, so you choose input A as Guitar, Mic, Aux, Variax etc... or combinations so you can have for instance Guitar, Aux and Variax all assigned to Input A, whilst you can have Input be assigned to Same, or the elements of the previous list, so in your situation you's assign Input A to Mic and Input B to Guitar using your example.
        Nick
    • Ignacio108 Just Startin' 10 posts since
      Sep 27, 2008
      Jun 6, 2011 11:33 AM (in response to Nick_Mattocks)
      Hi Nick, I come from the x3 live; whict that model I could separate assign effects to the guitar on tone 1 and to the voice (mic) in tone 2.
      With the HD500 I just learned how to make two separate threads but, panning the guitar and the mic at the center, but I get the delay from the guitar thread interfereing with the mic. I´d like the mixer to be at the very begining.
      I don´t know how to separate the effects.
      If you could help me...
      let´s say we want:
      comp for both
      delay, modulation and eq for guitar
      delay and eq for voice
      general reverb
      I don´t need amp, I use accoustic guitar
      im in a hurry i´ve a gig coming up soon
      thanks a lot
      Ignacio.
        Mar 26, 2007
        Jun 6, 2011 4:34 PM (in response to Ignacio108)
        let´s say we want:
        comp for both
        general reverb
        thanks a lot
        Ignacio.
        If you like, post your attempt at doing what you want here and I'll try and have a look at it to see if I can correct the error.  I suspect you may be experiencing an effect summing both signal paths to mono - not all FX are true stereo.
        Nick
          Sep 27, 2008
          Jun 6, 2011 5:35 PM (in response to Nick_Mattocks)
          Hi Nick, thanks a lot for your reply.
          Below are the threads
          Both amps are disabled (it´s an acoustic guitar on A path and a shure sm58 on B path)
          When the stereo delay on A is on it affects the voice.
          I´d like just a little delay on the voice and some volume control, delay on the guitar, and a general reverb
          comp + overdrive (from here on it splits) A) + volume pedal + sterero delay + amp (disabled) Mixer (panned center)  + reverb (plate)
        B) + eq + delay                                                    Mixer (panned center)
          Sep 27, 2008
          Jun 7, 2011 5:13 PM (in response to Nick_Mattocks)
          Sep 27, 2008
          Jun 7, 2011 5:14 PM (in response to Nick_Mattocks)
          Hi
    • phil_m Expert Line 6 User 4,243 posts since
      Jan 25, 2007
      Oct 31, 2010 6:12 AM (in response to dftpunk)
      There is definitely a vocoder effect.  It's under the filter section.  It's not shown on the product page, though.
      Also, regarding your original question - I don't think Kanye West is using a vocoder to do what he does.  I'm pretty sure it's using Auto Tune as an effect by setting it to some extreme settings.  You might be able to some similar type sounds with the vocoder, though.
      • Brion_Kean Just Startin' 391 posts since
        Dec 27, 2007
        Nov 1, 2010 4:35 PM (in response to phil_m)
        Vocoder is a sort of "manual" user-entry auto-tune? Meaning, the words / expressions that you say or sing, are set in pitch by what you play on the guitar. But yes, I think the sound Kanye / T-Pain / Cher, and many others have used to effect is Auto-Tune; Antares plugin is alot of fun.
        Interesting though, with the vocoder: if you play a chord, does it run your voice into the multiple notes of the chord, or can it do note recognition and shift to nearest correct note (as defined by the guitar or other input - keyboard perhaps?)
          Jan 25, 2007
          Nov 1, 2010 5:15 PM (in response to Brion_Kean)
          Autotune kind of works on the same principle as a vocoder.  You have a carrier signal and a formant, and the idea is to let the carrier control the pitch of the formant, roughly speaking.  Autotune sort of does this, but it's a lot more involved.
      Mar 26, 2007
      Oct 31, 2010 6:28 AM (in response to dftpunk)
      +1 to Phil
      The Vocoder effect is definitely in the HD500
      Nick
Bookmarked By (1)
