Nov 18, 2010 9:06 AM
Line 6 Foot switch
Like (0)
Hi Line 6,
I have two line 6 guitars a Variax acoustic 700 and a Variax 500 eletric. As I gig with both and run them from my XT live I wondered if you do or can advise where I can buy an A and B foot switch so I can switch between them without having to unplug each time I change instrument.
Awaiting your reply
Ray
Sorry, I've never seen this done before; not sure if there are any CAT-5 (network cable) A/B switching devices that could do this. We certainly do not have anything that will perform this... it's always been a one-to-one device usage. I think you'll have to disconnect at the guitar, put your current instrument on a stand, pick up the other one and re-connect the CAT-5 cable in your hand.
This assumes you're using the PODxt Live's Variax "digital" connection for guitar input...
Regards,
L6Perry
Hi Perry, thanks for your reply and I cant belive that I am the only person In the universe that has two variax guitars on stage at the same time. Is there any chance of line 6 looking into producing one of these A/B switch boxes?? It would be great if this would be possible.
Ray
Ray
You're not - see my previous reply above...
what hes saying is the ab switch has one input and two outputs. all you need to do is get a Y plug 1/4 to 1/4 at radoi shack and plug both guitars into that and just turn off the volume at the guitar your not using to acomplish the same thing. about 5 bucks for the plug
Boss LS2 Line switcher. You'll need an XPS box for each guitar or to run them off batteries.
Nick
flhrking wrote:
Hi Line 6,
Awaiting your reply
Ray
How's this for your answer?
The one I'm playing is connected using the VDI which suplies the power, the other is connected using the XPS DI power supply & DI box connected through the 1/4" input. NEITHER need to be switched just turn the volume down on the one your not playing at the time as they are both running and connected simultaneously. I'm using a Vetta do do this, but the XT and almost every other Line 6 pedalboard, or VDI equipped amp has two inputs.
So one VDI connected Vax, the other using the XPS for power so no batteries needed. BOTH plugged into the unit at the same time. NEVER need to unplug anything. The only thing is that one needs to be manually patch/bank changed for different sounds, the VDI connection should be pre-progammed to dial up the guitars you want for each of your amp patches.
Been doing this since 2006 when I bought my 700s without any problems.
And I bought an "MBrace" (Google this name and you'll find the original website, plus sever retailers who carry this simple, yet very effective walk-behind device. It's a whole lot less money than the other brand that requires a double braced cymbal stand as a base) and heavy duty atlas mic stand that I attached to hold my 2nd guitar. I attached it to the customized old keyboard T-style tube stand I chopped down that you can see sitting over my Roland Bass pedals (yes, I play some bass lines with my feet while playing guitar), while holding my FBV Longboard steady for stomp box and Vol/Wah pedal use.
I just took the bases off each mic stand so that one holds my amber 700 and the other side olds my mic stand which you can't see in this photo. Smallest footprint I could create based on my use of all this gear. It's VERY STURDY and it works perfectly and the stand weighs only a few pounds with the two mic stands on it.
I hope it helps anyone reading this,
Neal
PS - "Bean" and "Spider" users...sorry no easy way for you guys to do this.
Hi Neal,
Thanks for your help, I will try what you suggested but it would be handy if Line 6 could produce something.
Thanks again mate.
Keep rocking
Ray
http://www.radioshack.com/product/index.jsp?productId=2103991
i think it is as easy as buying one of these adapters and turning the volume down as neil said to the one your not using.
But I thought one part of the TRS lead supplies power to the Variax. Doesn't the Y-splitter mean that neither of his variaxes wil actually work? One will get power, but no sound transfer, while the other will get the reverse?
if hes using the xps or the ab to power the guitar it should work. its worth a try for 6 bucks i think
I misunderstood the product - I thought it was a splitter for one stereo to 2xMono leads. I see it's 1 stereo to 2xStereo, so my previous comment doesn't apply. But it brings up another comment - doesn't this mean that only half the required power will be delivered to each Variax?
But like you say - for $6 it's worth a try.
well the power supply that it uses is 2000 ma
from what i understand the guitar doesnt use that. or near to it. so at idle it shouldnt draw muchif anything at all. its not like it draws power to retain memory itsall on a flashed chip.
i might be wrong but i thought someone said the guitar uses a slight bit less than one amp while playing. as i recalllit was something like 850 ma. so if im correct then either way it should be neough for two.
as to line 6 making something. i think all there efforts are on the tyler guitar now.
