Nov 19, 2010 9:45 PM
Have I killed it?
Like (0)
I have a 2006 (I think) Variax 600... the batteries died the other day. One morning this week, I changed them early in the morning so I could take it with me to work for rehearsal that night. I tried to use it without the power supply and nothing... I plugged it up to the power supply, and it worked. Just checked everything and my meter read 9.6V... I then noticed that one of the middle AA batteries was put in incorrectly (negative & positive swapped). I just put it in correctly... the meter read 9.6V again... but still nothing. Power supply works. WTF?
check the battery holder for continuity.
also just try hooking up a 9 volt battery it could be your battery holder is damaged. if thats the case you can get one from line 6 or radio shack
In the original post, I said I had used the meter and got 9.6V. Have not tried the 9V battery yet, but if I'm getting 9.6 V from the battery holder... why would the 9V be any different?
Did that.... as I said in another post, the meter read 9.6V on the battery holder. Replacing it with a 9V didn't do any good either. I had it plugged into an amp and cranked the volume just to see what was up. There was a crackle sort of white noise... and that was it. Unplugging it got me silence.
I then opened it up... all connectors were undone and reseated. I shielded every place on the cage/coffin that was super close to metal on the circuit boards. I didn't see where to do anything else. Nothing helped. I really depend on this guitar and am playing a bunch in the next few months. Purchasing a new guitar right now isn't in the budget. I suppose I could once again drag six guitars to a gig, but would like to avoid it if at all possible.
I guess I could find a used 300 or so, dump my 600 patches on it... really does suck to have a reversed battery kill the thing...
Thanx for allowing me to vent.
Hello,
Have you opened up the guitar to see if all of your header connections are seated securely? Sometimes those headers can wiggle loose and cause problems.
If everything looks good then you have some sort of other hardware issue so you should contact a service center to have your guitar repaired.
http://line6.com/service_centers/
Line6Miller
I reseated all the connectors I could see without completely dismantling the thing.,, your authorized repair centers don't have a loaner program while yours is in the shop, huh?
Unfortunately, no. If you want, you can give us a call to see if there is anything our service people can do in regards to working with your local repair center to get your guitar back to you faster.
Service center turnaround times vary from place to place depending on the shop work load.
I'm not sure if we can do anything but it may be worth it to call us and talk to our service administrator to see if there is anything we can do.
(818)575-3600
Line6Miller
I finally tore the thing down and shielded the coffin with liquid electrical tape. In the process I inspected and cleaned all the connectors. When I put it back together.... the battery pack still doesn't work. Any ideas?
when i took mine apart i had put one of the connectore in backward . one or two can do that. check to see if its in the right way. also check for a burnt resistor near the connection. and try a nine volt . could just be the battery holder. if it works with the 9 volt then replace the battery holder. but give those resistors a good look see. sometimes they burn out if you connect the power supply witht e batteries in.
All the connectors are keyed.... I made sure they were in as keyed... however, I didn't check for resistors... I'll have to do that next time I change strings. Right now it's no biggie. It's a big PITA when I just want to plug it in quick. I did the 9V thing and same results. More than likely, when I reversed one of the batteries (see beginning of thread) I probably fried one. Thanx for the suggestions though.
... you killed it! I suggest you replace the fried resistor.
Hope this helps.
JellyWheat
