1468 Views 3 Replies Latest reply: Dec 1, 2010 4:26 PM by ricksox RSS
LowDownBassist Just Startin' 17 posts since
Oct 31, 2010
Nov 23, 2010 8:23 AM
How can I connect a FBV MkII Shortboard to two LD amps ?
I have two LD amps ( 400 Pro and 300 Pro ). I also have a FBV MkII Shortboard. I will be using a A/B box to drive signal to both amps from one bass guitar. Can I use a network switch or hub to send signal from the FBV Shortboard to the TWO LD amps ? If not, will this be a software patch some day down the road ?
Thanks,
Joe
  • ricksox UberGuru 11,600 posts since
    Mar 28, 2006
    Hi Joe,
      This would require a modification. So far, I've only seen one person post anything close to this but it was with an older FBV Shortboard MkI and a Spider Valve MkI and Flextone III.
      You can see the post here:
      http://line6.com/community/docs/DOC-1337
      We can't support this modification and I can't really say if it will work on your Lowdown.
      I can say with some confidence that I don't believe we'll be releasing a patch that will allow you to do this without a modification.
      Line6Miller
    Mar 28, 2006
    Hey Joe,
      Nice job! I'm glad it worked for you.
      Line6Miller
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
