2549 Views 5 Replies Latest reply: Jan 29, 2012 3:40 PM by aebirner RSS
aebirner Just Startin' 14 posts since
Sep 21, 2007
Nov 24, 2010 9:47 PM
POD X3 Live Power Supply Heat Problem
The sticker on the back of my POD X3 Live says it needs 9V AC 2000mA MINIMUM.  The PX-2 power supply is rated at exactly 2000mA.  I suspect this is why my PX-2 runs hot -- after three hours, it's not something you'd want to hold in your hand for more than a few seconds.  Is there a higher-amperage power supply available for the POD?
Thanks,
Andy
  • johnnieboy2 Just Startin' 2 posts since
    Nov 23, 2010
    Nov 28, 2010 11:34 AM (in response to aebirner)
    Re: POD X3 Live Power Supply Heat Problem
    It's a common problem.  2 amp current rating does not handle this unit well for extended use.  I took one failed unit apart and found it was the primary that opened up, burnt that is, and it took some real heat energy to do that.   I'm looking for a 2.5 - 3.5 amp unit for my Live 3 as we speak.  By the way, it's just a step down transformer, no electronic circuitry seen in the disassembled unit.
        Nov 23, 2010
        Dec 27, 2010 3:49 PM (in response to aebirner)
        I certainly would agree about the Variax issue, since these p/s have a real tendency to fry themselves without one attached.  I could not find a suitable unit to replace the original with the extra current margin, but I did find that Best Buy was selling the original unit from Line 6 for about $21 shipped so I bought it and it works great...for now.  That's a little better than the $35 price tag I was finding online everywhere else including ebay.  There is certainly no incentive for Line 6 to 'fess' up since the unit is 'old' news now.  They really should do a better job with their engineering on build quality.  The warranty is useless now so I would not worry about that and If I could find a larger current supply at 9vac I would use it in a heartbeat...no reason for that to cause a problem with the X3 Live.
