2216 Views 10 Replies Latest reply: Nov 30, 2010 5:36 PM by hwhalen RSS
ferryman95 Just Startin' 6 posts since
Nov 23, 2010
Nov 25, 2010 8:38 PM
Buffer *poff*
Hi.
So i have been having problems with my pod studio UX2, when i use the device the sound cuts off now and then, it doesn't effect recordning though.
have have changed the buffer to extra large which reduced the clicking and cracking but it's still not gone, i have gone throu the tutorials on your site "how to optimize your device  on windows 7" or something, and it hasn't helped im afraid.
i also got some sort of CPU spikes before, reinstalled the drivers and did some tweeks and they calmed down a bit, still there though, don't know if this i relavant, but i'll send a screen-shot just in case. ( post re-install of drivers and tweeks )
i feel that my computer should be able to handle the UX2 and software but i have tried everything i could think of, so now im turning to you.
Thanks
//A
  • Rowbi Expert Line 6 User 7,745 posts since
    Nov 25, 2006
    Nov 26, 2010 3:25 AM (in response to ferryman95)
    Re: Buffer *poff*
    during those CPU spikes, look at the processes tab and click on the CPU column header to sort (you may need to sort twice to get highest CPU users to the top) then you will see the process that's causing the spikes.  it's possible that it's something else that's doing that and intern the realtime audio that your UX2 is processing can't keep being realtime when the CPU is under such load, and it craps out.
  • LoonyBin-Fizzbin Gear Head 2,071 posts since
    Mar 26, 2007
    Nov 26, 2010 4:42 AM (in response to ferryman95)
    Re: Buffer *poff*
    I don´t think you will have an answer, unless you analize it yourself!
    You can use something like this!  http://www.vertexdsp.com/products_multiinspector.html
    http://www.vertexdsp.com/images/multiinspector/valign.png
    • hwhalen Just Startin' 178 posts since
      Mar 30, 2007
      Nov 28, 2010 7:59 AM (in response to ferryman95)
      Re: Buffer *poff*
      From another thread. http://line6.com/community/message/189697#189697
      Re: UX8 96000 Hz Usage
      Windows 7
      I have a new laptop that I'm testing also.
      Tonite I did the same stuff.
      No problem.
      Disk is only 5400rpm
      Spark up UX8, Reaper (64bit), Pod Farm 2
      Record two processed guitars, 1 processed bass 5 mic drum set.
      Clean... CPU under 10% disk read/write no problem.
      Once again UX8 settings
      96000 hz 32 bit
      ASIO settings Default buffer size 4096 32 bit
      ToneDirect & USB Audio Streaming at Extra Large.
      Latency? What latency? Crackling? Nope? Dropouts? Nope?
      Plugins? Nope?
      Works for me!
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
