2141 Views 8 Replies Latest reply: Dec 14, 2010 9:40 AM by scott93933 RSS
scott93933 Just Startin' 33 posts since
Jul 5, 2010
Nov 27, 2010 10:51 AM
Stereo output?
I have a question which will clearly prove, for once and for all, that I have still not read the POD X3 Live User Manual, which I promised myself I would do "when I had some free time."
I've honestly tried several times and I've even downloaded the manual as a PDF and searched for the terms, "stereo" and "pan," and was unable to find the answer to my question. So, with that out of the way, here's my question:
Q: How do I get stereo output from my POD X3 Live?
My bandmates and I are going from our effects processors into a mixer and then recording from there. The input to the mixer is a TRS (Tip, Ring, Sleeve) 1/4 inch stereo jack. There are two 1/4" TS (Tip, Sleeve) mono jacks on the POD X3 Live and although I could just go and get an adapter from Radio Shack, this would get me two identical channels of audio; it would just be splitting the mono signal from the POD X3 Live into two identical channels. As advanced as the POD X3 Live is, I'm certain that it must be capable of outputting its wonderful effects in true stereo, isn't that correct? If so, how do I do it?
Any help would be greatly appreciated!
   Thanks,
      Scott
  • grimm26 Just Startin' 303 posts since
    Nov 13, 2007
    Nov 27, 2010 11:33 AM (in response to scott93933)
    Re: Stereo output?
    It wouldn't be spliiting an identical signal.  The jacks are labeled left and right for a reason.  If you are using stero effects, you will get stereo.  If you use a dual tone setup and pan one left and one right, you'll get that.
      • pchapple Just Startin' 126 posts since
        Apr 20, 2010
        Nov 29, 2010 1:01 AM (in response to scott93933)
        Re: Stereo output?
        1) You will need an adapter cable with two mono jacks to one stereo jack.  Connect X3L 1/4" L and R to the mono jacks and the stereo one to your mixer.
        2) You will need to set your 1/4 OUTPUTS to be "Match Studio/Direct" instead of COMBO FRONT, etc.
        3) Panning is then affected by the settings on the STUDIO/DIRECT MIX page (I think!)
        4) Set "Live Out Level" switch on the top of the unit to LINE (probably - may depend on your mixer).
        See page 5.1 in the handbook for an example setup.
        It would be better if your mixer had XLR inputs, as the level match is better.
        • edstar1960 Iknowathingortwo 712 posts since
          May 25, 2010
          Nov 30, 2010 1:40 AM (in response to pchapple)
          Re: Stereo output?
          Also make sure that in OUTPUTS setting pages that you have the TONE you are using ON and the PAN set to center.  In other words, if using TONE 1, ensure that in OUTPUTS for Studio Direct and for 1/4 Live Out that TONE 1 is set to ON, and that the Pan for Tone1 is set to CENTER.  If the Tone you are using is set to either PAN LEFT or PAN RIGHTin 1/4 Live Out screen (or Studio Direct if you are using the Match Studio Direct Setting) then you will just get audio from one 1/4 Live out as described.  (See Manual 6-2, 6-3, 6-4).
  • namratiugsisats Just Startin' 5 posts since
    Jan 30, 2008
    Dec 13, 2010 8:45 PM (in response to scott93933)
    Re: Stereo output?
    It is, just hold down output and pan.  I even record left and right one at a time with the thing.  I'll post a clip of a recording I did with just the x3 live and a variax.  My band is trying to get downloads on itunes for this to hit the Billboard heatseeker charts...it's that pro sounding that I didn't even use an amp for this.  Again, TOTALLY with the x3 live and a variax.
      • silverhead Expert Line 6 User 9,592 posts since
        Apr 1, 2009
        Dec 14, 2010 9:02 AM (in response to scott93933)
        Re: Stereo output?
        Actually, it's the last bit of coughing that's screwing things up. You should be hiccupping instead..........
        Seriously, though....
        Gearbox is not only the file transfer program - it's also the computer-based editor. You should be able to do what you want within Gearbox.
