2935 Views 19 Replies Latest reply: Jan 5, 2013 7:18 PM by spaceatl RSS
mysocalledchaos Just Startin' 3 posts since
Dec 27, 2010
Dec 27, 2010 10:02 AM
HD400 Delay Tap Tempo (Dotted 8th)
I just got the HD400. I love it. alot. i was wondering how to change the delay type from quarter note to dotted 8th when it is set to tap mode. when i turn the dial, it just changes the BPM but it wont let me change the note value. please help. thanks alot.
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    Dec 27, 2010 10:05 AM (in response to mysocalledchaos)
    Re: HD400 Delay Tap Tempo (Dotted 8th)
    The tap tempo note value is fixed at 1/4 note in the HD400; it can't be changed.
    • forresal Just Startin' 163 posts since
      Aug 11, 2006
      Dec 27, 2010 10:35 AM (in response to silverhead)
      Wow.  That seems odd.  The manual seems to suggest that it can be changed.
      @mysocalled - glad to see you registered here and were able to get your question answered....
        Apr 1, 2009
        Dec 27, 2010 10:44 AM (in response to forresal)
        I'd love to find out it can be changed - can you point me to where the HD400 manual suggests that?
          Aug 11, 2006
          Dec 27, 2010 11:09 AM (in response to silverhead)
          Hey silverhead-
          I was looking at the Advanced Guide.
          Page 2.4 (briefly)
          Page 4.3
          and
          Ch. 8.
          Now I may be way off since I've not used the 400 and have only been looking into getting a HD500 (upgrading from an X3L).
          But as I read the manual, it suggests you:
          Select your delay model.  Use the Nav Key to scroll to Tap Ctrl.  Select "Control."  Then navigate to "time/tempo."  Since the tap is set to "control", the "tempo" will show with a note and bpm.  Then the dial to change.
          Again, this is just from reading the manual and note actually working with the unit.
          By doing the above, does it just change the BPM while leaving a quarter note showing?  That would really suck when trying to get alternate tempo repeats on the fly.  Pain in the butt to tap in a .8th....
          Just trying to help!
            Apr 1, 2009
            Dec 27, 2010 11:25 AM (in response to forresal)
            forresal wrote:
            By doing the above, does it just change the BPM while leaving a quarter note showing? ..
            Yes, unfortunately the tempo is fixed at 1/4 note taps. Whether you set the tempo using the footswitch, or set the bpm, the delay trails follow the 1/4 notes in terms of repetitions. That's what the manual means when it says:
            If you stomp out your desired 1/4 note rhythm on the TAP footswitch, this will set a new Tap Tempo, and FX3 models will then follow this new BPM value.
            Note that it specifies 1/4 note rhythm.
    • MaestrosounD Just Startin' 195 posts since
      May 13, 2007
      Dec 27, 2010 10:45 AM (in response to silverhead)
      Can it be changed on he 500?
        Apr 1, 2009
        Dec 27, 2010 10:48 AM (in response to MaestrosounD)
        Yes - it can be changed on the 500. I don't know the details since I don't have a 500 - I believe you have to set it manually in the patch parameters. Look in the manual or search on this forum - I've seen threads about it.
        • jimsreynolds Power User 2,227 posts since
          Jun 27, 43450
          Oct 27, 2012 12:34 PM (in response to silverhead)
          Yep, on the HD500  you can select either a tap tempo interval or a fixed time interval.  The pic below shows both along with the list of available intervals.  Click on it to zoom in.  Same deal with the desktop and Pro.  First I have heard that it was limited on the 3/400.
          • CairnsFella Just Startin' 205 posts since
            Sep 16, 2012
            Oct 27, 2012 10:06 PM (in response to jimsreynolds)
            I think its an intriguing limitation. Would have thought it was quite a noteable one, but I guess its lack of mention means it isnt being missed too much.
            Anyway, for once I will go home, pick up the guitar, and have a little smile regarding a HD500 benefit I never knew I had (all due respect to the unfortunate 300 and 400 owners of course)
    • Josiahfied Just Startin' 1 posts since
      Oct 26, 2012
      Oct 27, 2012 11:50 AM (in response to silverhead)
            It's a pretty dirty move to not have it in the 300 and 400 when previous pedals have had it. I just got my pedal in the mail yesterday (the 400) and when I found out there isn't even a dotted 8th tap delay on it.. Well. Seeing as there are multiple forums about it you get the point.
           Will there be an update where they allow us to change the delay note?
        Sep 16, 2012
        Oct 27, 2012 10:09 PM (in response to Josiahfied)
        If you have a look around you'll probably get the same impression as I, which is there is very little usually known about forthcoming updates. Indeed there is no explicit reason to believe there will be any more (but then I guess there is none to the contrary either).
        My own view (guess) is that this limitation is an intended (though not massivley highlighted) product differentiator, in which case I'd say it was unlikely.
      • PDKTDK Just Startin' 100 posts since
        Dec 24, 2011
        Oct 28, 2012 3:47 AM (in response to Josiahfied)
        I tend  to doubt it at this stage BUT....
        You can manually set they delay time (based on BPM) using a calculator like the one here: http://www.guitar9.com/delaytime.html
        It;s pretty simple.
      • lmeadors Just Startin' 2 posts since
        Apr 30, 2010
        Jan 5, 2013 6:33 PM (in response to Josiahfied)
        This seriously sucks. The specs for the two (400 v 500) really need to be more clear about this.
        While I appreciate people trying to help with the solution of tapping it, then doing some math and setting it to make it really do what you want...that would be fine if it wasn't a $400 piece of stage hardware.
        That's kind of hard to do between songs though.
        Epic fail, Line6.
        Mine came in the mail Wednesday and I'm ******.
        I'll be returning it on Monday.
  • Akeron Just Startin' 224 posts since
    Jul 23, 2011
    Oct 28, 2012 3:56 AM (in response to mysocalledchaos)
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
