Dec 30, 2010 1:54 AM
Noise in Record Out - Spider IV 15
Like (0)
Hello.
I'm liking the sounds out of the Spider IV 15, but am unable to record direct because of a loud, persistent noise from the record out port. This is present even when the amp is not turned on - just plugged in to power supply. Its pitch is roughly that of the D on 2nd string, and is at least as loud as the actual sound from the guitar at normal recording level. It is almost independent of volume levels. I've tried a couple of different power outlets, but no difference. I noticed it first when plugging into my computer, but read in the forum that this is often problematic because of the mismatched signal levels for mic vs line-in, but I've also checked it with recording interfaces including the M-Audio FastTrack and get the same, which also means I can't use the record out to send to a mixing desk.
Is this an earthing problem, perhaps? If it's a fault with the amp, it's still under warranty, but if not, does anybody have other solutions to try?
Thanks,
Cameron
Ah, I just found the answer here: http://line6.com/community/message/151247#151247
The problem is indeed a ground loop. I was running the FastTrack via USB from a computer with the same earthing as the amp; when I run the laptop on battery, no problem. Massively relieved! (I also tried a mic/guitar pre-amp as the intermediary, but I guess its impedence wasn't ideal, and maybe its lack of earthing was also an issue) There is still a slight bit of noise, but it's only the low-level stuff I'd expect from most amps.
Just one short suggestion, though: if your search didn't default to searching documents only, it would be rather quicker to find stuff ![]()
Cheers,
Cameron
