1404 Views 6 Replies Latest reply: Jan 23, 2013 4:56 AM by PrsSe RSS
killergege Just Startin' 74 posts since
Dec 25, 2009
Jan 3, 2011 9:16 AM
FBV Express + POD X3 tuner bug
Hi !
I noticed an annoying bug with the tuner of the FBV Express MkII when plugged in with a POD X3 (never tried with another unit though) : on the first use of the tuner, the "flat" light seem to be always switched on, even if the tuning is a "base" note.
In practice, each time a start a playing session, I check the guitar tuning :
- Press the tone button several seconds to enable the tuner
- Play the 6th (lower note) string.
- The FBV screens displays " E . " (note the dot, meaning that's an "Eb"), even if the string is correctly tuned to E
- Note that the POD X3 screen displays "E"
- if I lower the tuning of the string a little, the next tuning displayed on the FBV is... "Eb" again. (if I lower more, I get a "D")
- then if I move up the tuning, the correct tuning is displayed "E". And then it is always correct.
It seems that's always the first tune that is wrong, the "dot" being always on, and I need to force the FBV to display something else in order to be able to get the correct tuning.
If I disable the tuner to play and enable the tuner again, the bug doesn't reappear.
Gear :
- POD X3 "bean", not plugged on USB
- POD drivers, firmware, etc. up to date.
- FBV Express MkII, firmware up to date.
Anyone noticed this ?
    Jan 27, 2010
    Jan 4, 2011 10:26 AM (in response to killergege)
    Re: RE: FBV Express + POD X3 tuner bug
      Is the tuner reference of the POD X3 set to 440? If not, the tuner will display notes as sharp or flat when trying to tune to standard tuning.
      Thanks,
      David
      Line 6 Customer Support
    • PrsSe Just Startin' 8 posts since
      Oct 19, 2011
      Jan 23, 2013 4:56 AM (in response to Line6david)
      Hi David,
      I recently bought a FBV MK II floorboard.  In there is a possibilyty for tuning your guitar by holding one of the pedals; it goes in the tuning-mode.
      Normaly I prefer a tuning fork between my teeth  with A440 ( I'm 62 and oldfashioned LOL.) But.......there is a tuner in my Spider IV 30 and now a tuner in my floorboard.
      So, I gave it a try.
      Now the stupid things:  mij FBV controller tunes at E-flat, A-flat, D-flat, G-flat, B-flat and e-flat. So it drops half a tone  ???????????
      My Spider IV amp. tunes just right if I disconnect the floorboard and do the tuning with the led-lights themselves at the amp. Holding the pedals at the pedal give me a tuner with mol.
      Question:  Is there somewhere a possibilty to change the tuning in the floorboard?  And how do I do that?
      I searched the Amp spider manual and the complete FBV manual but there seems no possibility available.
      Any clues?
      Thanks in advance.
      PRSSE
      Danny from Holland.
  • ricksox UberGuru 11,600 posts since
    Mar 28, 2006
    Jan 25, 2011 9:09 AM (in response to killergege)
    Hello,
      Thanks for loading up that video. That helped me reproduce this. It does appear to be a bug.
      I'll log this in our bug database so our engineering department sees this. I don't think we have any plans to update the POD firmware and I'm honestly not sure if it's the POD or the pedal that is failing.
      Either way, I'll get it over to engineering. Thank you for the heads up on this one.
      Line6Miller
    Oct 19, 2011
    Jan 23, 2013 4:54 AM (in response to killergege)
    Re: FBV Express + POD X3 tuner bug
    Hi everybody,
    My Spider IV 30 Watt amp. tunes just right if I disconnect the floorboard and do the tuning with the led-lights themselves at the amp. Holding the pedals at the pedal give me a tuner with mol.
    Any clues?
    Thanks in advance.
    PRSSE
    Danny from Holland.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
